Page 15 of 18 1 2 13 14 15 16 17 18
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2436489
01/17/18 06:50 PM
01/17/18 06:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks and sounds good. Just out of curiosity, why wasn't the vacuum pump used in the video?
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: ProSport] #2436507
01/17/18 07:20 PM
01/17/18 07:20 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
That video happened to be the first pull. The pump belt was put on after a couple of pulls.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2436508
01/17/18 07:23 PM
01/17/18 07:23 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ok thanks up
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2436580
01/17/18 09:50 PM
01/17/18 09:50 PM
central il.
second 70 Offline
second 70  Offline
central il.
Great job. I see the only thing my cuda and your challenger have in common is they’re both 70’s, b5 blue and have hemi’s. Lol.
That car is a work of art. 👍. Mike
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: second 70] #2437469
01/19/18 02:20 PM
01/19/18 02:20 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Thanks for the compliments. Just wanted to build something different. Tired of all of the Chevy's & Fox Body Mustangs everywhere at all of the tracks. Gets old, gets boring.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2437542
01/19/18 04:28 PM
01/19/18 04:28 PM
What page is your video on?
I looked at 5 or 6 pages and then quit deciding to ask you help grin
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Cab_Burge] #2437553
01/19/18 04:44 PM
01/19/18 04:44 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
LOL, you had to go 1 more page. It is on the bottom of Page 7.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2440949
01/26/18 12:57 PM
01/26/18 12:57 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I picked up a Shaker hood. Next project is to make a custom drop base & a larger/taller Shaker scoop to fit the tunnel ram & dual Dominator carbs.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2440950
01/26/18 12:58 PM
01/26/18 12:58 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Close fit.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2441017
01/26/18 03:10 PM
01/26/18 03:10 PM
an8sec70cuda Offline
I'm looking forward to seeing what you do w/ that shaker scoop! I'd like to have one for my car, even though I love my cowl hood.
Mike Ford's old KOS challenger (plum crazy w/ a single carb B1 motor IIRC) had a raised shaker scoop that I always thought was cool.
Harry Schilling has one on his burgundy/maroon hemicuda too that looks good.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: an8sec70cuda] #2441038
01/26/18 03:53 PM
01/26/18 03:53 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I just can't bring myself to do the cowl hood as good as they look on E Bodies. I have thought about doing an extra tall T/A style hood like 340Rick had or a 5" tall Six Pack style hood.
Yeah, I always dug Mike Ford's old Purple Challenger's set up. I do have to stretch the rear of the hood opening to clear the rear carb so the base & scoop will also be stretched & raised to match the opening.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2441048
01/26/18 04:16 PM
01/26/18 04:16 PM
I'm assuming you'll just attach the scoop to the hood?
Is the hood a fiberglass lift-off?
CHIP
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: an8sec70cuda] #2441061
01/26/18 04:39 PM
01/26/18 04:39 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Nope, I am still making it a true shaker. The Scoop & base will mount to the engine. The hood is a Fiberglass bolt on. I am going to still use the factory Hood Pins but I know I will also need more to keep the front from ripping off of the car, so I am going to make a mount to attach some Butterfly Dzus fasteners from up underneath that will mount from the hood latch area that will be accessible reaching in towards the grille.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2441146
01/26/18 07:25 PM
01/26/18 07:25 PM
That sounds like it'll be very nice!
I'm sure you've seen them already, but the way Schilling's is done...he raised the area around the scoop on the hood up and then left the shaker itself looking more stock height. Mike Ford's was all done by making the scoop itself taller.
I think Schilling's hood looks better.
CHIP
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: an8sec70cuda] #2441224
01/26/18 10:23 PM
01/26/18 10:23 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Schiling's looks pretty good like that. I am going to try to leave the hood at it's stock height and since I am stretching the opening towards the rear a few inches the taller scoop should look more proportional since it will be longer also.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2441328
01/27/18 01:48 AM
01/27/18 01:48 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Keep us updated. I had one started and stalled because for a non body guy its an epic adventure of trial and error and alot of sticky fiberglass.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: V10nacuda] #2441341
01/27/18 01:59 AM
01/27/18 01:59 AM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Will do. I am gathering the rest of the parts now. I found the scoop from one source. The base plate and adapter ring from another source and the seal, fasteners,and of course the shaker decal and other bits from a third source.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2454647
02/20/18 04:57 PM
02/20/18 04:57 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
I received everything for my shaker scoop, base plate, outer adapter ring & lid today. Let the cutting & hacking begin.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2454745
02/20/18 08:56 PM
02/20/18 08:56 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I have nothing to add to this thread. I'm just here to keep checking up on this awesome build laugh2. Great job. Great looking car thumbs
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Uncle Barry] #2454787
02/20/18 10:01 PM
02/20/18 10:01 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Yeah, what he said. iagree
Old Geezer Racing
