Converting 67 GTX to power steering questions #2436279
01/17/18 01:17 PM
01/17/18 01:17 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I want to convert my 67 GTX to power steering. I have to get a two groove crank pulley and have a question. I would like to know if the crank pulleys on 67 440's are any different than later years (different part number)? I think I have a forged crank two groove pulley in my collection of parts but it is likely from a later model year car. Also, will I have to use a different water pump pulley when changing to a two groove crank pulley?
Re: Converting 67 GTX to power steering questions [Re: 440mopar] #2436377
01/17/18 04:10 PM
01/17/18 04:10 PM
Chicago
PurpleBeeper Offline
Chicago
I'm not sure about '67, but I did this swap on my '70 and I'm trying to remember.
1. I "think" your newer crank pulley will work, but you should check the outer diameter of the pulley in the belt groove (piece of string). There's "something" in the back of my head about some crank pulleys having one offset bolt hole & others being completely symmetrical (not sure)
2. As long as the water pump pulley still lines up with the crank pulley, I don't believe you have to change it (I didn't)
Also, my motor is a hodge-podge of years & I did have to use a couple washers here & there to get all the pulleys to line up straight with the power steering.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Converting 67 GTX to power steering questions [Re: PurpleBeeper] #2436702
01/18/18 02:38 AM
01/18/18 02:38 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Also note that A/C cars used a larger diamter pump pulley than a non A/C car.
Re: Converting 67 GTX to power steering questions [Re: Jeremiah] #2436723
01/18/18 04:57 AM
01/18/18 04:57 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It's the other way around, A/C cars had a smaller pulley to spin the pump faster.
Re: Converting 67 GTX to power steering questions [Re: 440mopar] #2436747
01/18/18 09:59 AM
01/18/18 09:59 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Don't forget that the steering columns are different lengths
