SHOCKS W/ SS SPRINGS #2435423
01/16/18 02:28 AM
01/16/18 02:28 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
When I ran a few B bodies in the 70's, I'd use station wagon long length shocks w/ SS springs and they worked well. With my 273/4 (300 HP), 9" converter and a 4.10 gear '65 Dart, I'll be using 2 L 3200 lbs SS springs. Any thoughts for a longer shock that's more over the counter than custom?
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2435428
01/16/18 02:42 AM
01/16/18 02:42 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Shock Extenders...
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2435450
01/16/18 03:52 AM
01/16/18 03:52 AM
C body for a 1971 Imperial non gas shocks if you can still find them. If not look at some 1971+ 1/2 and 3/4 ton 2 whd pick up shocks, you may need to add a bushing in the top part or use bigger upper bolts to hold them in place scope
Re: SHOCKS W/ SS SPRINGS [Re: Cab_Burge] #2435587
01/16/18 01:13 PM
01/16/18 01:13 PM
moparx Offline
moparx  Offline
cab, the pickup shocks have the same upper and lower mounts as the B & C body, and imperial shocks, and are a tad shorter than the imperial shocks. those are the LS39 upper, which is a sleeve for a 1/2" bolt, and an L2 lower, which is the rubber bushing only that fits the 11/16" lower plate stud. the B & C shock is 13.750 collapsed, 22.875 extended, while the pickup shock is 14.750 collapsed, 24.375 extended. the imperial shock for 1970-73 [and are the only years that are longer than the B & C body] is 15.600 collapsed, and 26.320 extended. this from my monroe master catalog. hope this can help someone decide something for their application. the pickup shocks may have a stiffer valving due to load hauling, but that would depend, i suppose, on the shock manufacturer.
beer
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2435640
01/16/18 02:18 PM
01/16/18 02:18 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Calvert Racing Shocks will give you adjustability and not break the bank....I have used them front and rear with SS springs and like them
Curator at Adams County Speed Shop
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2435690
01/16/18 03:26 PM
01/16/18 03:26 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I used to use the Monroematic pickup truck shocks with my SS springs. They seemed to work OK when I was using bias ply D.O.T. slicks but when I switched to M/T Drag Radials I started having problems. The car would hook and then spin again 40 feet out. I switched to some inexpensive Competition Engineering shocks and problem solved.
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2435739
01/16/18 04:47 PM
01/16/18 04:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
D100 oil ft shocks AutoZone # 82054 19.95 each on the Duster project.
512/727 with SS 002 & 003. Seemed less stiff than the same-application gas shock. Had to look through the Gabriel catalog to get the correct upper mount bushing size, but they let me have fairly free run of the place. Not sure how well they work until Spring thaw. Still trying to confirm how much tire I can cram under the thing.
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2435821
01/16/18 06:27 PM
01/16/18 06:27 PM
crabman173
crabman173
I have to say that shocks will have a very big effect on how well the SS springs work--You have a race car right? So buy some real race shocks
It is impossible to beat the KONI SPA-1's on the front If you set them where they pull apart the easiest you are ready--If you can't source them use QA-1
On the rear the QA-1 adjustables are killer--call them for part numbers about three clicks is great starting point 4 clicks on killer tracks
You just need to look at pro cars and see what is on there--I know most are going Caltracs these days but even so ask the pros what shocks they are using
Makes ALL the diff in the world to go ahead and drop the loot on real race shocks
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2436010
01/16/18 11:38 PM
01/16/18 11:38 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
During the 70's I ran a 426 street wedge and 2 6 pack cars. SS springs and SW shocks. Cars hooked on the street and at the track. Now I have a lighter car with a 273 and in no way am I making the same HP and TQ. Two left handed SS springs are more than enough for this combo. I had read that gas filled shocks do not perform as standard shocks and one of the members replied in same. I don't need a big dollar rear shock. I'm just looking for something that I know work with my B body cars and do the same with my Dart. Every shock that I found has been a gas shock. So I'm trying to find that standard rear shock, and as Cab Burge mention, '71 Imperial or something comparable.
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2436014
01/16/18 11:54 PM
01/16/18 11:54 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I've been using SS springs for over 50 years, still use them. The big thing is that they extend enough.....you need at least 24". I use Comp Engineering 3 way adjustables set at 50/50. Priced right, and work good. The thing the old Imperial shocks had going for them is that they had the long extension. The new MP and other aftermarket shocks have that handled.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: SHOCKS W/ SS SPRINGS [Re: A/MP] #2436110
01/17/18 02:01 AM
01/17/18 02:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also still use SS springs and I just use the Mopar Performance extended shocks. They have no adjustments as they are just a basic shock that extends longer so the SS springs can work. Been working fine on my 63. Ron
