Re: Ignition timing over heating?
[Re: da50r]
#2435849
01/16/18 07:22 PM
01/16/18 07:22 PM
Posts: 3,884 Oregon
hooziewhatsit
It may not be related, but I changed up how my timing works, and mine seems to run a lot cooler on the highway now.
[Re: da50r]
#2437774
01/20/18 01:10 AM
01/20/18 01:10 AM
RapidRobert
0.0632683" is (1) degree. measure out a strip of paper for how many degrees you need. IE 2&1/4" (2.246") is 35.5 degrees. How hot is "hot" Confirmed with a good mech gauge? is this a new ring breakin? I'd think 30 deg (1.898") at 2000 RPM would be enough to keep it from overheating from retarded timing.
[Re: da50r]
#2437799
01/20/18 02:19 AM
01/20/18 02:19 AM
Posts: 5,161 CT
GTX MATT
CT
YES. I think alot of old cars overheat because their owners won't check the timing or don't set it correctly. When its too retarded more of the bore is exposed to more flame front, and you get more heat transfer into the coolant.
Vacuum advance helps too. With stock type timing curves removing the vacuum advance will often cause them to run hot.
