'73-'74 spool engine mounts #2435449
01/16/18 03:52 AM
01/16/18 03:52 AM
3
340clone Offline OP
340clone  Offline OP
While I've got the 440 out of my '74 Charger, I figured it would be a good time to replace the mounts. Year One sells just the insulators, but say they need to be pressed in to original mounts. Is this difficult? I wonder if pressed means simply slipped in, or mechanically pressed in?
The only other ones I see online are NOS so they're 45 years old. What is everyone doing to replace this type of mount these days?
Thanks!
Re: '73-'74 spool engine mounts [Re: 340clone] #2435453
01/16/18 04:03 AM
01/16/18 04:03 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
The stock isolators are pressed into the bracket like a control arm bushing.Not a slip fit in other words.
Re: '73-'74 spool engine mounts [Re: 340clone] #2435455
01/16/18 04:09 AM
01/16/18 04:09 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They aren't a real tight fit. You don't need a press, but you will need to straighten the small end. With that said, the aftermarket parts store inserts are garbage...
Re: '73-'74 spool engine mounts [Re: 340clone] #2435459
01/16/18 04:26 AM
01/16/18 04:26 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
The urethane replacement bushings will reuse the OE metal sleeve.You will have to dig/cut grind out the old rubber bushing material first.
Like these I'm sure you saw on Year One's page
https://www.yearone.com/Product/chrysler-b-body/mu344
Re: '73-'74 spool engine mounts [Re: Jim_Lusk] #2435462
01/16/18 04:34 AM
01/16/18 04:34 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I tack welded mine. They just seemed too loose even after swaging the end.
I filled the open space with silicone caulking. Been that way since 1997. I'd think that would be a little less harsh than poly inserts.
Re: '73-'74 spool engine mounts [Re: 340clone] #2435534
01/16/18 11:54 AM
01/16/18 11:54 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have used the NOS spool mounts on two different cars and they have been fine. No issues with the rubber on them. BTW, P4120757 was a mopar performance mount pkg that was made all the way up to sometime in the mid 90`s.
Re: '73-'74 spool engine mounts [Re: 340clone] #2435604
01/16/18 01:32 PM
01/16/18 01:32 PM
3
340clone Offline OP
340clone  Offline OP
Good info!
I've noticed that some of the NOS mounts online have orange or white paint on them. It looks like there are a few different part numbers stamped on them, each with either White, Orange or Green stamped next to the number. I guess the paint color determined the part number.
Does anyone know what the difference in colors are? I've only seen Orange and White. Are they interchangeable?
Re: '73-'74 spool engine mounts [Re: 340clone] #2435654
01/16/18 02:31 PM
01/16/18 02:31 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Originally Posted By 340clone
Good info!
All the same. I have wondered about the multiple part numbers, too.
Re: '73-'74 spool engine mounts [Re: 340clone] #2435662
01/16/18 02:51 PM
01/16/18 02:51 PM
Locomotion Offline
Locomotion  Offline
Buying the inserts and digging out the old rubber is a huge PIA. I only did it once. Schumacher mounts aren't cheap, but saves a lot of time & effort.
As for the dabs of paint, they could be inspection marks, like they have done on rears and other parts as they went down the assembly line. i.e.: bolts tightened.
Re: '73-'74 spool engine mounts [Re: autoxcuda] #2435682
01/16/18 03:19 PM
01/16/18 03:19 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
That's what worked for me as well.
A torch will make quick work of removing the rubber. If you buy mounts from NAPA try to get the ones made in Mexico, the ones from India need to have the rubber drilled out for the long bolt to pass through.
Re: '73-'74 spool engine mounts [Re: 340clone] #2435817
01/16/18 06:23 PM
01/16/18 06:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The made in India mounts last about a day if your lucky. The rubber is horrible. I had a made in India trans mount on my car and it lasted about a month or so.
These on ebay seem like a decent deal for NOS
https://www.ebay.com/itm/NOS-Mopar-Motor...epid=1911257443
Re: '73-'74 spool engine mounts [Re: 340clone] #2435827
01/16/18 06:32 PM
01/16/18 06:32 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Rock auto has a complete mount for $20.79 but only the left side. Right side is shown not available.
http://www.rockauto.com/en/moreinfo.php?pk=3462252&cc=1079951&jsn=583
Re: '73-'74 spool engine mounts [Re: 340clone] #2436027
01/17/18 12:08 AM
01/17/18 12:08 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Thanks!
Actually they could be maybe 25-30 Years old still being made up to mid 90s as a regular replacement easy to find back then from Mopar dealers?
My car got a NOS set locally ( not in USA so maybe they are actually OOOOLD ) and they are holding nice. Also got Anchors bushing replacement from Rockauto thinking on replace the old ones, but find the NOS ones couple of weeks later I got the bushings. Still on their boxes, but they seem to be nice pieces and easy to replace.
Re: '73-'74 spool engine mounts [Re: NachoRT74] #2436277
01/17/18 01:16 PM
01/17/18 01:16 PM
moparx Offline
moparx  Offline
filling the voids in spool type mounts with windshield urethane has worked well for me for many years. in my opinion, way better than just filling them with silicone.
beer
Re: '73-'74 spool engine mounts [Re: 340clone] #2437690
01/19/18 10:12 PM
01/19/18 10:12 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Maybe try to find NOS aftermarket ones the older the better,look for boxes that say made in USA & without bar codes,keep checking Ebag & run all the different part #s,2369 seems to be the magic# you will find them sooner or later.
TRW# 83087 2 on Ebag now.
Re: '73-'74 spool engine mounts [Re: 340clone] #2437915
01/20/18 01:28 PM
01/20/18 01:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW the spool mounts are expensive and last I checked (2 weeks ago) they are not available. Just buy a good quality factory mount. If you are worried about it breaking at launch, get a chain or a torque strap.
Coming soon!!!!
Re: '73-'74 spool engine mounts [Re: 340clone] #2437922
01/20/18 01:38 PM
01/20/18 01:38 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
https://www.ebay.com/itm/NOS-Mopar-1973-79-Big-Block-Motor-Mounts/322856299036
ChetBay has them $90 and free shipping with long bolts and nuts. The real ones last a Loooong time.
Re: '73-'74 spool engine mounts [Re: 340clone] #2438515
01/21/18 06:08 PM
01/21/18 06:08 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Looks like someone bought the ones I showed the same day I posted as they were listed for a looong time......
