BB Stroker harmonic balancer with Jesel belt drive
#2434873
01/15/18 07:22 AM
01/15/18 07:22 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I am finally getting the last few items together to complete a mock up of this new stroker im building. Some confusion i have is which Ati super damper do i need with the jesel belt drive. From what i understand, it has to have an extended hub and be a 2 piece.
Anyone have the correct part numbers and i assume i will have to space out my alternator to get the pulleys to line up. Any help would be appreciated
About the combo: 400 stroker to 498. 13.25:1 Indy cnc325 -1s from Dwayne Porter Comp solid roller at 726/713 and 272/276 @50 Indy single plane intake with either 1050 or 1150 dom. (Prob 1150) 68 b body @ 3900 lbs with jerico 4 gear and 4:30 rear gear
Re: BB Stroker harmonic balancer with Jesel belt drive
[Re: Chargerfan68]
#2435313
01/15/18 11:33 PM
01/15/18 11:33 PM
Chargerfan68
New York, USA
Thanks for the replies. I didnt have a balancer since this was a fresh build so i just ordered the steel super damper part no ati 917127E. Thanks for that info DoubleD. Now for the water pump, if i run an electric water pump (like mezierre) (and no stock style water pump housing), (1) is there enough clearance to make cam timing changes without removing the elect water pump? (2) do i still have to run spacers for the pump body or do they make one that works with the jesel system?
I think the water pump is now the only thing left to sort out and get. I just ordered the oiling system and pan but its a few weeks out according to the company. I am going to run a crank scraper, so i have to work that into it also
[Re: Chargerfan68]
#2435732
01/16/18 04:43 PM
01/16/18 04:43 PM
Chargerfan68
New York, USA
Great. Thats what i was hoping for. To make cam timing changes without having to remove wp housing/ pump. Thanks
That is a nice timing pointer Andy. Ill have to see about ordering one of those. Thanks for your input.
[Re: Chargerfan68]
#2435736
01/16/18 04:46 PM
01/16/18 04:46 PM
Chargerfan68
New York, USA
Al, Just curious: did you have to clearance that world block for the jesel cover? I have a friend with that block and i am trying to convince him to get the belt drive.
