Window net mounting pics?
#2433900
01/13/18 02:33 PM
01/13/18 02:33 PM
Posts: 10,022 MN
JERICOGTX
MN
Need some ideas on how others have mounted their window nets.
Thanks.
69 GTX
68 Road Runner
Re: Window net mounting pics?
[Re: JERICOGTX]
#2433986
01/13/18 05:38 PM
01/13/18 05:38 PM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Run the attachment tubes vertical. The rear tube can be fixed with a bracket at the top near the main hoop and be removable with a single fastener at the bottom. The front tube can use a rod end at the bottom to allow movement and a quick release latch at the top with the catch welded to the inside of the halo. Installing the tubes like this will allow you to bend them out away from the driver to give maximum elbow room. Just don't get outside of the outer plane of the cage. Measure where you want the net to fit and have one made. It makes a much easier and nicer looking job when the net fits the car.
[Re: JERICOGTX]
#2434024
01/13/18 06:47 PM
01/13/18 06:47 PM
Posts: 10,022 MN
JERICOGTX
MN
I am planning on having Stroud make a custom net. Was just curious on how others mount theirs.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2434230
01/14/18 02:05 AM
01/14/18 02:05 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use the seat belt latch on all of mine. I'll see if I can find some pics.
[Re: JERICOGTX]
#2435733
01/16/18 04:44 PM
01/16/18 04:44 PM
Posts: 625 Indianapolis In. usa
Quickrunner
This is how we did mine. Only thing I don't like is the GM logo on the seatbelt latch that came with the kit. LOL
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
