Finish of Lower Control Arms #243383
03/04/09 08:56 PM
03/04/09 08:56 PM
Gibsonburg, Ohio USA
dodgem_doug Offline OP
Just finished bead blasting and installing new bushing on my lower control arms. I'd like to give these the factory look.
Weren't these covered with cosmolem for shipment from the factory? I'm not sure what color to paint but I'm thinking of clear coating when complete.
Any suggestions and pictures would be of great help.
Thanks, Doug
Re: Finish of Lower Control Arms [Re: dodgem_doug] #243384
03/04/09 09:33 PM
03/04/09 09:33 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Heres one dipped in cosmoline! They were held at the ball joint end.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Finish of Lower Control Arms [Re: BradD] #243385
03/04/09 09:36 PM
03/04/09 09:36 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
nice
Re: Finish of Lower Control Arms [Re: moparmojo] #243386
03/04/09 10:10 PM
03/04/09 10:10 PM
Buckle of corn belt ,c. lll.
420SIX Offline
420SIX  Offline
Used Resto Ricks Quasimoline urethane. Nice dry finish, no sticky problems to deal with.
Re: Finish of Lower Control Arms [Re: 420SIX] #243387
03/04/09 10:12 PM
03/04/09 10:12 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Those look very nice.
Did you coat the bare metal on the ends with anything?
Re: Finish of Lower Control Arms [Re: Neil] #243388
03/04/09 11:19 PM
03/04/09 11:19 PM
420SIX Offline
420SIX  Offline
Everything was cleaned ,primered,and painted..
Re: Finish of Lower Control Arms [Re: 420SIX] #243389
03/05/09 10:58 AM
03/05/09 10:58 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I dip mine in real cosmoline just like the factory did. You end up with highlighted streaks that you can't get with spraying them. Besides, how are you going to get paint coverage way down in the middle of the arm? The bushings are installed AFTER dipping.
Re: Finish of Lower Control Arms [Re: hemi70se] #243390
03/07/09 04:25 PM
03/07/09 04:25 PM
Leesburg, VA
V
VA_Mopars Offline
VA_Mopars  Offline
V
Leesburg, VA
To those guys that dipped their's, where did you find the cosmoline and what process did you use?
Thanks,
Joe
Re: Finish of Lower Control Arms [Re: VA_Mopars] #243391
03/07/09 04:44 PM
03/07/09 04:44 PM
None
71rm23 Offline
71rm23  Offline
None
Just did a web search...Here's one for instance
http://www.mil-specproducts.com/cosmo_l.aspx
Re: Finish of Lower Control Arms [Re: 71rm23] #243392
03/07/09 06:28 PM
03/07/09 06:28 PM
Leesburg, VA
V
VA_Mopars Offline
VA_Mopars  Offline
V
Leesburg, VA
Thanks,
I had previously searched and am aware of this vendor as well as others online... I am more interested in finding out from those that have already done it, what source they used... As you can see from the two postings, the color/tone appears different and I was trying to find out what source each used...
Thanks again for the suggestion,
Joe
Re: Finish of Lower Control Arms [Re: VA_Mopars] #243393
03/07/09 08:56 PM
03/07/09 08:56 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
It is a CRC product I bought through Fastenal Supply, I bought a 5 gal pail which works out perfectly to be deep enough for dipping.
Re: Finish of Lower Control Arms [Re: hemi70se] #243394
03/07/09 10:15 PM
03/07/09 10:15 PM
Leesburg, VA
V
VA_Mopars Offline
VA_Mopars  Offline
V
Leesburg, VA
Thanks...
I appreciate the details,
Joe
Re: Finish of Lower Control Arms [Re: VA_Mopars] #243395
03/07/09 10:34 PM
03/07/09 10:34 PM
MO
cdp Offline
cdp  Offline
MO
I bought some spray cans from Schafco, who owns the Cosmoline trade mark. They explain their products on their website. I mixed and matched and bought a case.
Have yet to experiment.
http://www.schafco.com/cosmoline.asp
Re: Finish of Lower Control Arms [Re: cdp] #243396
03/07/09 10:56 PM
03/07/09 10:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
what other parts are on a car that needs cosmoline?
Re: Finish of Lower Control Arms [Re: cdp] #243397
03/08/09 11:28 AM
03/08/09 11:28 AM
montreal,quebec,canada
buzz440 Offline
buzz440  Offline
Hate to rain on your parade but...... Houghton owns the rights to the Cosmoline name they are the original makers of this product.... the real name of the product is; Cosmoline 1102.I have a 20 litre pail of the stuff, it's the real deal.
Later, BUZZ
Re: Finish of Lower Control Arms [Re: buzz440] #243398
03/08/09 12:00 PM
03/08/09 12:00 PM
grand rapids mi. usa
P
Purestocker Offline
Purestocker  Offline
P
I bought a block of the stuff from an army surplus outlet, you heat it up and it thins out nice and you can dip your arms in it, works well but it does stay a little tacky like the oe stuff,
Re: Finish of Lower Control Arms [Re: Purestocker] #243399
03/09/09 08:27 PM
03/09/09 08:27 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Here's the CRC in a spray can. It could be applied heavy to get the run affect. I cleaned my arms and washed off all the org while rebushing the ft end. My arms weren't blasted or painted as I am not doing a resto just trying to preserve it, so there was some surface rust I had left alone. Seems to work very well and only need to get 1 can insted of a bucket.
Re: Finish of Lower Control Arms [Re: rrunner] #243400
03/09/09 08:28 PM
03/09/09 08:28 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
part #
Re: Finish of Lower Control Arms [Re: rrunner] #243401
03/09/09 08:29 PM
03/09/09 08:29 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
And the arm. I did mine laying flat, should have hung then and let it run
Re: Finish of Lower Control Arms [Re: rrunner] #243402
03/09/09 09:41 PM
03/09/09 09:41 PM
SE Pa.
LimeliteAero Online content
LimeliteAero  Online Content
SE Pa.
The CRC spray on stuff looks pretty good to me.
