having a big problem need help! #2433420
01/12/18 03:16 PM
01/12/18 03:16 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I know this not the truck section but, my truck does not want to start! it will spin over hit once and keep on spining till i turn the key off.. could the the crank sensor got south on me? I unemployed i need help! I cycle key but i did it one time to many i just got part of the code p04...
thank for any info!
Re: having a big problem need help! [Re: BigTerry] #2433424
01/12/18 03:21 PM
01/12/18 03:21 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
What do you mean by hit once? Engine starts running and then goes back to "spinning" as in back to cranking mode?
Year and engine would help too.
Facts are stubborn things.
Re: having a big problem need help! [Re: larrymopar360] #2433426
01/12/18 03:22 PM
01/12/18 03:22 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
yes
Re: having a big problem need help! [Re: larrymopar360] #2433429
01/12/18 03:24 PM
01/12/18 03:24 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
year and modle would be the first place to start
Re: having a big problem need help! [Re: BigTerry] #2433430
01/12/18 03:24 PM
01/12/18 03:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Year? Engine? Did you check for spark? Fuel pressure?
Re: having a big problem need help! [Re: bonefish] #2433432
01/12/18 03:27 PM
01/12/18 03:27 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
sorry it a 2008 ram with 5.7 hemi auto..
the little throttlebody indictator or low voltage light is on..
it was running fine till i stop to get coffee..
Re: having a big problem need help! [Re: BigTerry] #2433439
01/12/18 03:36 PM
01/12/18 03:36 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Did you put cream and sugar in your coffee?
Re: having a big problem need help! [Re: BigTerry] #2433443
01/12/18 03:38 PM
01/12/18 03:38 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I think that's an emissions code. Either 02 sensor or Cat Converter. I'm betting 02 sensor. But I'm not familiar enough with late model stuff to know if that would cause your no start issue.
Re: having a big problem need help! [Re: larrymopar360] #2433453
01/12/18 03:52 PM
01/12/18 03:52 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
humm i never heard that causing that but this truck has been showing me thing i never seen before.. i never had this problem on my old trucks.. sigh...
Re: having a big problem need help! [Re: BigTerry] #2433462
01/12/18 04:06 PM
01/12/18 04:06 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Re: having a big problem need help! [Re: BigTerry] #2433469
01/12/18 04:13 PM
01/12/18 04:13 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
would a weak battery could cause this?
Terry Sansom
Re: having a big problem need help! [Re: BigTerry] #2433492
01/12/18 04:51 PM
01/12/18 04:51 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
shruggy
Re: having a big problem need help! [Re: BigTerry] #2433496
01/12/18 05:00 PM
01/12/18 05:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The new Mopars are susceptible to weird stuff when the battery gets weak.
Re: having a big problem need help! [Re: stumpy] #2433525
01/12/18 06:04 PM
01/12/18 06:04 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
got it running i punch the bottom on the fuel tank it start up! yay! i guess im going need a fuel pump..
Re: having a big problem need help! [Re: BigTerry] #2433580
01/12/18 08:46 PM
01/12/18 08:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
In-tank pumps use the fuel in the tank to help them cool; running a vehicle under 1/8 filled arguably shortens the life of the pump.
You can usually get a few starts out of it using a rubber mallet to whack the tank, but yeah, it's definitely time for a pump.
Re: having a big problem need help! [Re: BigTerry] #2433595
01/12/18 09:16 PM
01/12/18 09:16 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Why is he throwing a code? Unrelated I guess.
Re: having a big problem need help! [Re: topside] #2433636
01/12/18 10:37 PM
01/12/18 10:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Hope you got it covered Terry. up
I also keep a minimum half tank in the manual pump old timers.
Keeps the moisture and other crud out.
It's just as easy to nickle and dime the 1/2 full line as it is the empty line.
I have mechanical Aptitude.
I can screw up anything.
Re: having a big problem need help! [Re: BigTerry] #2433800
01/13/18 10:55 AM
01/13/18 10:55 AM
ky.
K
kenworth_goose Offline
K
ky.
This is one of the trucks that has the fuel issue with the TIPM
Re: having a big problem need help! [Re: BigTerry] #2434575
01/14/18 07:16 PM
01/14/18 07:16 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
wow the bolts on the bed are frozen I could not get them loose even electric impact gun! I guess i drop the tank not looking forward to doing that..
Re: having a big problem need help! [Re: BigTerry] #2434579
01/14/18 07:24 PM
01/14/18 07:24 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
JB Blaster. Good stuff.
