What do these numbers mean on a 9 3/4 axle housing? #2432653
01/11/18 03:03 AM
01/11/18 03:03 AM
SC
V194 Offline OP
V194  Offline OP
SC
Stamped into the tube are:
10 2 9A2
10 10 9 C7
603080 3
Any ides what these refer to?
Re: What do these numbers mean on a 9 3/4 axle housing? [Re: V194] #2432654
01/11/18 03:10 AM
01/11/18 03:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
assembly/inspection dates ?? & application
10 2 9A2 Thursday 10/2/69 A2
10 10 9 C7 Friday 10/10/69 C7
603080 3 E-body 4.10 DANA60
scope
Re: What do these numbers mean on a 9 3/4 axle housing? [Re: V194] #2432655
01/11/18 03:16 AM
01/11/18 03:16 AM
SC
V194 Offline OP
V194  Offline OP
SC
Ok Great Thanks.
Re: What do these numbers mean on a 9 3/4 axle housing? [Re: V194] #2433059
01/11/18 09:58 PM
01/11/18 09:58 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
6bblgt what does the number 3 at the end of the 603080-3 mean compared to an axle that would have 603080-5. What would be the differences in -3 and -5, maybe an assembly line or something else. Both would be 410 gear ratio but what else is different or what is the difference between -3 and -5.
Re: What do these numbers mean on a 9 3/4 axle housing? [Re: 6bblgt] #2433220
01/12/18 03:18 AM
01/12/18 03:18 AM
AndyF Offline
AndyF  Offline
That is a nice chart. I've never seen it before, where did it come from?
Re: What do these numbers mean on a 9 3/4 axle housing? [Re: AndyF] #2433232
01/12/18 04:21 AM
01/12/18 04:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I've seen it before, but I just search internet images for "DANA 60 BOM" the source points back to Moparts
just found this one & it sheds light on the dash # - source points to a JK forum
Re: What do these numbers mean on a 9 3/4 axle housing? [Re: V194] #2433573
01/12/18 08:31 PM
01/12/18 08:31 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
603080 bill of material would mean either 345 or 410 or 456 identifying number for a 69 to 71 E Body Rear End. I take the 69 would mean the beginning of the model build starting around July of 1969 to have rear end ready for the 1970 E Bodies. The number after the Bill of Material number 1 2 4 is for a 354 why use three different numbers on an E Body rear end for what is stated in the above post. Why use 3 5 for a 410 and 6 7 for a 456. It states the number is a Ratio, Differential and End Yoke Options, what does that mean. Are there differences in the yokes for 354 and 2 for 410 and 2 for 456?
1971 HEMI E BODY REGISTRY
