Re: having a big problem need help!
[Re: BigTerry]
#2433424
01/12/18 03:21 PM
01/12/18 03:21 PM
Posts: 15,879 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
What do you mean by hit once? Engine starts running and then goes back to "spinning" as in back to cranking mode?
Year and engine would help too.
Facts are stubborn things.
[Re: larrymopar360]
#2433429
01/12/18 03:24 PM
01/12/18 03:24 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Year and engine would help too. year and modle would be the first place to start
[Re: BigTerry]
#2433443
01/12/18 03:38 PM
01/12/18 03:38 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I think that's an emissions code. Either 02 sensor or Cat Converter. I'm betting 02 sensor. But I'm not familiar enough with late model stuff to know if that would cause your no start issue.
[Re: larrymopar360]
#2433453
01/12/18 03:52 PM
01/12/18 03:52 PM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
I think that's an emissions code. Either 02 sensor or Cat Converter. I'm betting 02 sensor. humm i never heard that causing that but this truck has been showing me thing i never seen before.. i never had this problem on my old trucks.. sigh...
[Re: topside]
#2433636
01/12/18 10:37 PM
01/12/18 10:37 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Hope you got it covered Terry. running a vehicle under 1/8 filled arguably shortens the life of the pump. I also keep a minimum half tank in the manual pump old timers. Keeps the moisture and other crud out. It's just as easy to nickle and dime the 1/2 full line as it is the empty line.
I have mechanical Aptitude. I can screw up anything.
[Re: BigTerry]
#2434579
01/14/18 07:24 PM
01/14/18 07:24 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
wow the bolts on the bed are frozen I could not get them loose even electric impact gun! I guess i drop the tank not looking forward to doing that.. JB Blaster. Good stuff.
