Transmission lines
#2433214
01/12/18 02:55 AM
01/12/18 02:55 AM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
I want to get away from the stock transmission lines on my Demon. Does anyone know what size fitting goes in the 727? Or if I can just screw an AN fitting on to the stock fittings?
eBay-cdwmotorsports
Re: Transmission lines
[Re: cdwmotorsports]
#2433233
01/12/18 04:24 AM
01/12/18 04:24 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
They may be 1/4 NPT, do you have a 1/4 NPT tap to see with ?
#2433291
01/12/18 11:27 AM
01/12/18 11:27 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Pretty sure they are 1/8" NPT. I use -6 AN also. Many will say to use the more expensive PTFE lined AN hose, but it isn't needed. It is better quality, but not required for trans lines.
#2433342
01/12/18 01:20 PM
01/12/18 01:20 PM
Posts: 4,209 New York
polyspheric
New York
Yes, use 3/8" line, don't want to slow down the cooling cycle. Put a B&M filter in the line somewhere before the cooler that you can service it to keep it clean (don't accumulate trash inside the cooler) and detect friction material loss.
Boffin Emeritus
#2433421
01/12/18 03:19 PM
01/12/18 03:19 PM
Posts: 3,089 Michigan
A727Tflite
Here is an image of one of those magnefine filters. Nothing wrong with the B & M except you have to cut then dispose of it each time you want to take a look. Plus it takes up a bunch of room. Flow is not an issue with the smaller filter but if you use one of these on a 1/2" line setup use the bug filter fittings. We did exhaustive test on these filters. And you Chrysler dealer techs will remember seeing these filters in our Reman trans kits. Those that used them ended the multiple trans failures when you followed the directions.
#2433449
01/12/18 03:47 PM
01/12/18 03:47 PM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-6 Teflon. Yes, it's worth the little extra money. We've used some of the cooler with fan packages back under the car to eliminate some of the spaghetti at the front of the car. Has worked OK.
#2433513
01/12/18 05:36 PM
01/12/18 05:36 PM
Posts: 2,079 CA
crackedback
CA
-6 teflon/PTFE hose. I used some from this place. The only issue I had was the ends were not the standard sizes so the fancy AN wrenches didn't fit. Chinese stuff I'm sure and tolerances. Worked OK after that was figured out. http://anfittingsdirect.com/
#2433521
01/12/18 05:57 PM
01/12/18 05:57 PM
cdwmotorsports
Martinsville, IN
Since my car is outside and it’s snowed about 5” this AM does anyone have the ability to measure from the trans to in front of the radiator? I need to know line length so I can order this stuff. I’m using aeroquip startlite line and fittings.
eBay-cdwmotorsports
[Re: A727Tflite]
#2433543
01/12/18 06:51 PM
01/12/18 06:51 PM
Cab_Burge
The FWD cars used 5/16" line, most RWD cars in the day used 3/8" and so did most gas engine trucks, and we went to 1/2" lines on the 47/48 diesel for extra cooling of the lube.
All the early(1957 to 1974) Mopar V8 and leaning six cars automatic trans. cars I worked on, including the street hemi cars, had 5/16 O.D. lines on the tranny up to the radiator heaters I'm not sure what size lines my 2006 Ram 3500 4WD truck with the factory towing packages has for line I.D. or O.D. sizes Maybe I should go check My first Dodge CTD Ram 2500 24 valve (1998 1/2) had the factory towing package on it, I added a tranny temp gauge and found out that it should have had a thermostat to the external tranny cooler, the trans temps never got above 140F when not towing, summer or winter in the CA Mojave desert I haven't added a gauge to this truck due to not wanting to worry about the trans temps
#2434356
01/14/18 12:38 PM
01/14/18 12:38 PM
cdwmotorsports
Martinsville, IN
Since my car is outside and it’s snowed about 5” this AM and it’s -9 does anyone have the ability to measure from the trans to in front of the radiator? I need to know line length so I can order this stuff. I’m using aeroquip startlite line and fittings.
eBay-cdwmotorsports
#2434713
01/14/18 11:41 PM
01/14/18 11:41 PM
Cab_Burge
What year and body style? The Plymouths have two inch longer wheel base so they may have different length lines also OOPS I just reread the first post
#2435346
01/16/18 12:48 AM
01/16/18 12:48 AM
RapidRobert
I was thinking that someone priorly said that the ID somewhere in the internal cooling passages inside the trans makes going to a 3/8 line a moot point. If this is bogus I will for sure tap to the next larger size as those brass 1/8 NPT/inverted flare fittings are available in the next larger size along with useing 3/8 line.
[Re: A727Tflite]
#2435581
01/16/18 12:57 PM
01/16/18 12:57 PM
RapidRobert
^^^ noted, thank you. On my next one I will tap/go to 3/8 line
#2438842
01/22/18 02:50 AM
01/22/18 02:50 AM
cdwmotorsports
Martinsville, IN
What trans. cooler are you guys running? I'd like to Drag Week my car in the next year or so. I'm looking at this one... Derale 13900 Derale Electra-Cool Remote Fluid Coolers 13900
eBay-cdwmotorsports
#2438856
01/22/18 03:50 AM
01/22/18 03:50 AM
RapidRobert
people have said that the "stacked plate" types transfer more heat
[Re: rowin4]
#2439057
01/22/18 03:58 PM
01/22/18 03:58 PM
RapidRobert
No, just mount it in the most convenient appropriate position for the easiest/shortest hose routing.
#2439267
01/22/18 11:49 PM
01/22/18 11:49 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
What trans. cooler are you guys running? I'd like to Drag Week my car in the next year or so. I'm looking at this one... Derale 13900 Derale Electra-Cool Remote Fluid Coolers 13900 I run a B&M stacked plate cooler, 8" 4500 converter, no fan, and nothing through the radiator. I have done 5 drag weeks with my road weight at about 4200lbs with passenger and gear. Now I do not have a temp gauge but I have run the same fluid for at least 8 years and it still looks good. The few times I have hit the trans cooler with a temp gun it has been 150-180* not that its much of an indication of fluid temp but I didn't think that was bad.
68 Barracuda Formula S 340
#2439447
01/23/18 10:42 AM
01/23/18 10:42 AM
Bad340fish
Tulsa OK
It is mounted down low in front of the radiator.
#2439565
01/23/18 02:55 PM
01/23/18 02:55 PM
an8sec70cuda
I use a trans cooler I bought from Advance Auto Parts about 20 years ago. Mounted in front the radiator. Works great, lol.
[Re: an8sec70cuda]
#2439585
01/23/18 03:42 PM
01/23/18 03:42 PM
cdwmotorsports
Martinsville, IN
That’s what I have but I want it plumbed with AN and braided line so I can save my stock lines for a later project.
eBay-cdwmotorsports
#2439593
01/23/18 03:55 PM
01/23/18 03:55 PM
an8sec70cuda
I have -6AN lines on it w/ a hose clamp. Backyard yes, but it works.
[Re: J_BODY]
#2439846
01/24/18 01:50 AM
01/24/18 01:50 AM
cdwmotorsports
Martinsville, IN
I use -6 line.... pipe to AN fitting on trans. Straight on the front, 45 degree on rear. Jbody, is the transmission side or hose side a 45 degree fitting? I can’t find a 45 degree -6AN to 1/8” NPT fitting anywhere
eBay-cdwmotorsports
