Re: Transmission lines [Re: cdwmotorsports] #2435394
01/16/18 01:43 AM
01/16/18 01:43 AM
A727Tflite Offline
A727Tflite  Offline
Going to larger lines does add flow. All the internal geartrain lube passages are the same size between the 42/44/46/47/48 RE-RH.
All the three speeds are 1 to 1 running down the road. The over drives have planetary action in the OD unit in 4th gear. That's why they need larger lines than the 3 speeds.
Re: Transmission lines [Re: A727Tflite] #2435581
01/16/18 12:57 PM
01/16/18 12:57 PM
^^^ noted, thank you. On my next one I will tap/go to 3/8 line
Re: Transmission lines [Re: cdwmotorsports] #2438842
01/22/18 02:50 AM
01/22/18 02:50 AM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
What trans. cooler are you guys running? I'd like to Drag Week my car in the next year or so.
I'm looking at this one...
Derale 13900 Derale Electra-Cool Remote Fluid Coolers 13900
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2438856
01/22/18 03:50 AM
01/22/18 03:50 AM
people have said that the "stacked plate" types transfer more heat
Re: Transmission lines [Re: cdwmotorsports] #2438980
01/22/18 01:51 PM
01/22/18 01:51 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have a stacked plate cooler. Does it matter which position the cooler lines are mounted ?
Re: Transmission lines [Re: rowin4] #2439057
01/22/18 03:58 PM
01/22/18 03:58 PM
No, just mount it in the most convenient appropriate position for the easiest/shortest hose routing.
Re: Transmission lines [Re: cdwmotorsports] #2439267
01/22/18 11:49 PM
01/22/18 11:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run a B&M stacked plate cooler, 8" 4500 converter, no fan, and nothing through the radiator. I have done 5 drag weeks with my road weight at about 4200lbs with passenger and gear. Now I do not have a temp gauge but I have run the same fluid for at least 8 years and it still looks good. The few times I have hit the trans cooler with a temp gun it has been 150-180* not that its much of an indication of fluid temp but I didn't think that was bad.
68 Barracuda Formula S 340
Re: Transmission lines [Re: cdwmotorsports] #2439305
01/23/18 12:36 AM
01/23/18 12:36 AM
Martinsville, IN
Martinsville, IN
Bad fish, where did you mount your cooler?
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2439447
01/23/18 10:42 AM
01/23/18 10:42 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It is mounted down low in front of the radiator.
Re: Transmission lines [Re: cdwmotorsports] #2439565
01/23/18 02:55 PM
01/23/18 02:55 PM
an8sec70cuda Offline
I use a trans cooler I bought from Advance Auto Parts about 20 years ago. Mounted in front the radiator. Works great, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Transmission lines [Re: an8sec70cuda] #2439585
01/23/18 03:42 PM
01/23/18 03:42 PM
Martinsville, IN
Martinsville, IN
That’s what I have but I want it plumbed with AN and braided line so I can save my stock lines for a later project.
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2439593
01/23/18 03:55 PM
01/23/18 03:55 PM
I have -6AN lines on it w/ a hose clamp. Backyard yes, but it works.
CHIP
Re: Transmission lines [Re: J_BODY] #2439846
01/24/18 01:50 AM
01/24/18 01:50 AM
Martinsville, IN
Martinsville, IN
Originally Posted By J_BODY
I use -6 line.... pipe to AN fitting on trans. Straight on the front, 45 degree on rear.
Jbody, is the transmission side or hose side a 45 degree fitting? I can’t find a 45 degree -6AN to 1/8” NPT fitting anywhere
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2439922
01/24/18 10:55 AM
01/24/18 10:55 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Fragola has the -6AN to 1/8" NPT fittings with 45 degree angle
https://www.summitracing.com/parts/fra-482362-bl/overview/
I used the straight adapter fittings and the angled hose ends instead of angled fittings,
Re: Transmission lines [Re: cdwmotorsports] #2439935
01/24/18 11:34 AM
01/24/18 11:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
^ fitting right out of the trans. Local welding shop has Redhorse stuff in stock. Bought one there.
C&R out of Aussi makes a nice 10x11 plate type cooler with -6 fittings welded on to it. I was having issues with the trans temp staying too high, especially if running two classes. I had one of those "log" type heat exchangers under the front bumper on my car. I retained that, but also went with a new crossflow rad that had the trans cooler mounted in the tank. That took care of my prob. I have the C&R cooler, but so far it's just wall art.
Re: Transmission lines [Re: cdwmotorsports] #2440338
01/25/18 12:49 AM
01/25/18 12:49 AM
Martinsville, IN
Martinsville, IN
Thanks Jbody and RTSE4ME
eBay-cdwmotorsports
