Transmission lines #2433214
01/12/18 02:55 AM
01/12/18 02:55 AM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I want to get away from the stock transmission lines on my Demon. Does anyone know what size fitting goes in the 727? Or if I can just screw an AN fitting on to the stock fittings?
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2433221
01/12/18 03:34 AM
01/12/18 03:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I use -6 line.... pipe to AN fitting on trans. Straight on the front, 45 degree on rear.
Re: Transmission lines [Re: cdwmotorsports] #2433231
01/12/18 04:02 AM
01/12/18 04:02 AM
Martinsville, IN
Martinsville, IN
Thanks J-body
By chance know the pipe side size?
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2433233
01/12/18 04:24 AM
01/12/18 04:24 AM
They may be 1/4 NPT, do you have a 1/4 NPT tap to see with ?
Re: Transmission lines [Re: cdwmotorsports] #2433291
01/12/18 11:27 AM
01/12/18 11:27 AM
an8sec70cuda Offline
Pretty sure they are 1/8" NPT. I use -6 AN also. Many will say to use the more expensive PTFE lined AN hose, but it isn't needed. It is better quality, but not required for trans lines.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Transmission lines [Re: an8sec70cuda] #2433321
01/12/18 12:33 PM
01/12/18 12:33 PM
moparx Offline
moparx  Offline
yup. 1/8"NPT. the A518 "may" have gone to 1/4"NPT, as the line size increased to 3/8" od. tube from 5/16".
beer
Re: Transmission lines [Re: cdwmotorsports] #2433342
01/12/18 01:20 PM
01/12/18 01:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Yes, use 3/8" line, don't want to slow down the cooling cycle.
Put a B&M filter in the line somewhere before the cooler that you can service it to keep it clean (don't accumulate trash inside the cooler) and detect friction material loss.
Boffin Emeritus
Re: Transmission lines [Re: cdwmotorsports] #2433389
01/12/18 02:26 PM
01/12/18 02:26 PM
Martinsville, IN
Martinsville, IN
Thanks gentlemen.
Polyspheric thanks for the tip I’ll look and see what I can find.
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2433417
01/12/18 03:15 PM
01/12/18 03:15 PM
A727Tflite Offline
A727Tflite  Offline
Buy a metallic cooler line filter housing - trans fluid ignites pretty easy if the plastic filter body melts or fractures. Magnefine Boss had the best filter out there - used a magnet on the inlet side plus a good filter media with bypass inside. Screwed together so you could take the filter out for examination.
We tested it and it took over 4 grams of clutch debris to block the filter media. That means you aren't likely to go far when you fail that much friction material. And with the magnet it continues to collect any ferrous material. The aluminum gets trapped in the filter media.
The FWD cars used 5/16" line, most RWD cars in the day used 3/8" and so did most gas engine trucks, and we went to 1/2" lines on the 47/48 diesel for extra cooling of the lube.
Re: Transmission lines [Re: cdwmotorsports] #2433421
01/12/18 03:19 PM
01/12/18 03:19 PM
A727Tflite Offline
A727Tflite  Offline
Here is an image of one of those magnefine filters. Nothing wrong with the B & M except you have to cut then dispose of it each time you want to take a look. Plus it takes up a bunch of room. Flow is not an issue with the smaller filter but if you use one of these on a 1/2" line setup use the bug filter fittings. We did exhaustive test on these filters. And you Chrysler dealer techs will remember seeing these filters in our Reman trans kits. Those that used them ended the multiple trans failures when you followed the directions.
Re: Transmission lines [Re: cdwmotorsports] #2433449
01/12/18 03:47 PM
01/12/18 03:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
-6 Teflon. Yes, it's worth the little extra money. We've used some of the cooler with fan packages back under the car to eliminate some of the spaghetti at the front of the car. Has worked OK.
Re: Transmission lines [Re: cdwmotorsports] #2433513
01/12/18 05:36 PM
01/12/18 05:36 PM
CA
crackedback Offline
crackedback  Offline
CA
-6 teflon/PTFE hose.
I used some from this place. The only issue I had was the ends were not the standard sizes so the fancy AN wrenches didn't fit. Chinese stuff I'm sure and tolerances. Worked OK after that was figured out.
http://anfittingsdirect.com/
Re: Transmission lines [Re: cdwmotorsports] #2433521
01/12/18 05:57 PM
01/12/18 05:57 PM
Martinsville, IN
Martinsville, IN
Since my car is outside and it’s snowed about 5” this AM does anyone have the ability to measure from the trans to in front of the radiator? I need to know line length so I can order this stuff. I’m using aeroquip startlite line and fittings.
eBay-cdwmotorsports
Re: Transmission lines [Re: A727Tflite] #2433543
01/12/18 06:51 PM
01/12/18 06:51 PM
All the early(1957 to 1974) Mopar V8 and leaning six cars automatic trans. cars I worked on, including the street hemi cars, had 5/16 O.D. lines on the tranny up to the radiator heaters shruggy
I'm not sure what size lines my 2006 Ram 3500 4WD truck with the factory towing packages has for line I.D. or O.D. sizes confused Maybe I should go check work My first Dodge CTD Ram 2500 24 valve (1998 1/2) had the factory towing package on it, I added a tranny temp gauge and found out that it should have had a thermostat to the external tranny cooler, the trans temps never got above 140F when not towing, summer or winter in the CA Mojave desert shock work
I haven't added a gauge to this truck due to not wanting to worry about the trans temps realcrazy whistling
Re: Transmission lines [Re: cdwmotorsports] #2433571
01/12/18 08:04 PM
01/12/18 08:04 PM
A727Tflite Offline
A727Tflite  Offline
I stand corrected on the passenger car lines - yes, 5/16".
Re: Transmission lines [Re: cdwmotorsports] #2434356
01/14/18 12:38 PM
01/14/18 12:38 PM
Martinsville, IN
Martinsville, IN
Since my car is outside and it’s snowed about 5” this AM and it’s -9 does anyone have the ability to measure from the trans to in front of the radiator? I need to know line length so I can order this stuff. I’m using aeroquip startlite line and fittings.
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2434487
01/14/18 04:40 PM
01/14/18 04:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'll be in the shop shortly and I can measure my Dart if needed.
53" from the rear fitting to the face of the radiator support in a straight line.
Re: Transmission lines [Re: cdwmotorsports] #2434713
01/14/18 11:41 PM
01/14/18 11:41 PM
What year and body style?
The Plymouths have two inch longer wheel base so they may have different length lines also confused
OOPS blush I just reread the first post blush
Re: Transmission lines [Re: cdwmotorsports] #2435333
01/16/18 12:22 AM
01/16/18 12:22 AM
Martinsville, IN
Martinsville, IN
Thanks Justinp61.
Cab_burge, 4 extra inches wouldn’t have hurt the pocket book 😬
eBay-cdwmotorsports
Re: Transmission lines [Re: cdwmotorsports] #2435346
01/16/18 12:48 AM
01/16/18 12:48 AM
I was thinking that someone priorly said that the ID somewhere in the internal cooling passages inside the trans makes going to a 3/8 line a moot point. If this is bogus I will for sure tap to the next larger size as those brass 1/8 NPT/inverted flare fittings are available in the next larger size along with useing 3/8 line.
