Re: 440 A/C Compressor Bracket Dilemma for the Big Block Experts
[Re: 340clone]
#2433377
01/12/18 02:04 PM
01/12/18 02:04 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Something weird there. My 74 400 doesn’t have anything on pasanger side. The bracket attached to the intake runs to the “front” coil support provision.
IN fact i have never seen ANY special provision anywhere to any block allong the years. AC bracket setups used whatever EXISTANT PROVISION, like the car didn’t get AC.
[Re: NachoRT74]
#2433519
01/12/18 05:55 PM
01/12/18 05:55 PM
Posts: 6,224 JERSEY
RJS
JERSEY
[Re: 340clone]
#2433689
01/13/18 12:22 AM
01/13/18 12:22 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
400 and 440 use different brackets.probally have a set from one om my 440 Imps.But havent seen them in 20 years.Rocky
Chrysler Firepower
[Re: 340clone]
#2433756
01/13/18 03:23 AM
01/13/18 03:23 AM
340clone
Thanks for the input so far! I will post some pics of the previous Edelbrock and the bracket it used.
Since I am now running an AVS style intake, I am thinking that I will need a bracket from a '68-'70 440? Does that seem right?
[Re: 340clone]
#2433836
01/13/18 12:18 PM
01/13/18 12:18 PM
NachoRT74
Valencia, España
The bracket setup changes due the year, not due the engine... I mean, maybe some lenght differences can be found between a 400 and 440 BUT if both are 73/74, the setup itself is the same and will look the same without measure it.
[Re: 340clone]
#2433844
01/13/18 12:34 PM
01/13/18 12:34 PM
NachoRT74
Valencia, España
Shame I don't have clear pics of my engine bay where the Compressor bracket setup its shown clearly
[Re: 340clone]
#2433857
01/13/18 12:59 PM
01/13/18 12:59 PM
NachoRT74
Valencia, España
ok FINALLY found pics... they were on my cell phone, that's why I never found it on my PC. This is for 73/74 BB. Even 400 and 440 can change lenghts due the diff block height, the bracketing setup should be remain the same. The only bracket running somehow to "passenger" side goes to front coil provision and is not "a pipe kind" like earliers
I'm using an Eddy performer intake, which is ALLMOST the same than a stock one, just a tad higher ( maybe half an inch ) so had to mill down a bit the coil bracket provision on intake to fit correctly the A/C bracket without bending. On a stock intake, this compressor bracket will be over the coil bracket, not underneath like I made to fit.
Also the front area close to valley pan front rail. Had to notch the intake to fit the rail bracket.
I hope it helps
[Re: 340clone]
#2433878
01/13/18 01:50 PM
01/13/18 01:50 PM
NachoRT74
Valencia, España
and, 440 eddy performer aluminium intake, same look than stock, maybe just like mine, half an inch higher, so more ventury effect than stock... just like me, trimm it, paint it and done. No EGR provision https://www.ebay.com/itm/Edelbrock-Perfo...VuU&vxp=mtrI got mine in $75 in perfect conditions... I bet can be found cheaper, but to get you the idea. just diff on the manifold vacuum port side from the iron stock piece. 383/400 got it on correct side, but planes inverted
[Re: 340clone]
#2433883
01/13/18 02:02 PM
01/13/18 02:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
He wants to run an AVS, which is the square bore pattern, not the spreadbore the thermoquad or edelbrock intakes have.
[Re: 340clone]
#2433890
01/13/18 02:14 PM
01/13/18 02:14 PM
NachoRT74
Valencia, España
he WANTS TO or he will run because is the one he got ? the opening will not disturb running a squarebore carb on a spreadbore intake, like backwards... just need to consider the mounting provisions if needed... spacer/adaptors are available around in just around $10-15. anyway, not telling what must be done, but suggesting, looking forward to the "stock look" on a more correct stock setup as he told, but for the year as I suggest. Opinions, ideas, just that
[Re: 340clone]
#2433912
01/13/18 02:45 PM
01/13/18 02:45 PM
Supercuda
About to go away
About to go away
up yours
Why he's doing it is irrelevant, he is doing it and that is what he's asking. Stock 73/74 setups apparently will not work with his combo and he's asking what does. I don't have a setup like what he is using and googling around doesn't show a brace on the compressor on any of the images I could find, 68 Charger 383.
PS, stock choke won't work right with an AVS on a spreadbore intake with an adapter.
[Re: 340clone]
#2434318
01/14/18 11:00 AM
01/14/18 11:00 AM
NachoRT74
Valencia, España
Ok, once again the intake deal was as mentioned as an OFF TOPIC deal just posting opinions/suggestion looking forward for a correct stock look for the year ( since he pointed out was changing for more stock look ). Also compairing the intake itself since he pointed out the intake he was to use got a boss/provision for some A/C bracket ? hardly doubt that, since intakes never were issued being for A/C or not. Compressor bracketing was designed to be installed on existant provisions. Nothing more. The bracketing for BB 73/74 is posted on the pics. They are from my own Charger 74 400, which MUST be the same for 440. Maybe lenght differences due the diff block height ? sure, but setup itself should be the same. More pics are welcomed to be sure.
dunno on AVS, but TQs got a thick phenolic or cardboard spacer between intake and carb itself. If AVS/AFBs got a spacer like that, the adaptor can be in replacement fo that one . The adaptor is about the same thickness than the thick original spacer.
[Re: RJS]
#2434508
01/14/18 05:22 PM
01/14/18 05:22 PM
340clone
I have some spare brackets lying around, so maybe I can make something work like in the first photo in this thread. Would a 5/16 bolt in a coil bolt hole be sufficient if I had a bracket that would fit? It looks like that was done here possibly?
