I have a '74 Dodge Charger with a '440 that had an Edelbrock intake, and I want to bring it back to a more stock set up.
I am installing a cast iron intake dated 8/28/67 and a '71 AVS that I had rebuilt. No problems there.
The issue is that the Edelbrock intake has a boss on the passenger side with a bolt hole that a factory bracket from the A/C compressor bolts into. The cast iron intake will not accept that bracket. I am thinking that style bracket is for later cars.
Would I need a '67-'71 set of B or E body A/C brackets for this application? I know it seems like a Frankenstein set up, but will be very stock looking and I will get to run my AVS rather than a Thermoquad.
All help appreciated!
