2006 dakota pcm question #2341141
07/21/17 08:23 PM
07/21/17 08:23 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
have a glitch in the system that is not sending the correct voltage to the new transmission. Wires have been verified to be in good shape, has anyone used a remanufactured PCM? I see them on the net and they say no need to bring to a dealer. Other possible issue might be with the integrated control module.
Any insight would be great
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2341160
07/21/17 09:09 PM
07/21/17 09:09 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
https://www.automodulesource.com/
I bought one for a Jeep Liberty from here. Reasonably priced, sent them the VIN and it came plug and play. I would buy another from them if I needed to.
Dennis
Re: 2006 dakota pcm question [Re: cudaboy] #2341180
07/21/17 09:51 PM
07/21/17 09:51 PM
pacific northwest
pacific northwest
Dennis
What symptoms were you correcting?
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2366753
09/07/17 01:06 AM
09/07/17 01:06 AM
pacific northwest
pacific northwest
Update, took to the dealer and they found a ground pin out in the pcm, fixed that and got about 300 miles on it and the same issue came up with an engine light.
Took it back now they say its the PCM and want $1500 to fix
need advise here on other options like a reman PCM
any help would be great,,,, Thanks
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2366772
09/07/17 01:41 AM
09/07/17 01:41 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Check around in your area for a pcm rebuilder. I got mine redone locally for $375. Took it in and a day later got it back.
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2366921
09/07/17 01:08 PM
09/07/17 01:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What code is it setting ? Ron
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2367022
09/07/17 04:09 PM
09/07/17 04:09 PM
Allenton Mi
dodgecharger68 Offline
Allenton Mi
I went through this last year on a 2007 Dakota. Mine pcm went bad and took out part of the trans that shifts the gears. Its like a servo pack in the transmission. Get a new pcm I believe I paid like $450.00 installed. You could get it rebuilt and do it yourself also. This is a known problem with Dakotas.
Re: 2006 dakota pcm question [Re: 383man] #2367226
09/07/17 10:55 PM
09/07/17 10:55 PM
pacific northwest
pacific northwest
They didn't tell me just that the pcm was bad.
Re: 2006 dakota pcm question [Re: dodgecharger68] #2367228
09/07/17 10:57 PM
09/07/17 10:57 PM
pacific northwest
pacific northwest
I just ordered one off E bay for $250 and will install my self
Said its "plug and play" so we will see if it fixes the problem
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2367229
09/07/17 10:59 PM
09/07/17 10:59 PM
pacific northwest
pacific northwest
BTW rebuilt transmission, new convertor and solenoid pack
Ran good for about 300 miles then didn't want to take off
in low gear.
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2367356
09/08/17 09:25 AM
09/08/17 09:25 AM
Allenton Mi
Allenton Mi
On my 2007 Dakota it was the solenoid pack that crapped out.
They put in a solenoid pack first and the pcm crapped the new
solenoid pack. They had to put a second solenoid pack in and the pcm at the same time. Its possible you will be replacing the solenoid pack again. I hope this helps it was very frustrating for me. Took like 2 weeks to fix everything.
Re: 2006 dakota pcm question [Re: dodgecharger68] #2376133
09/24/17 11:09 PM
09/24/17 11:09 PM
pacific northwest
pacific northwest
So the remanufactured PCM did not fix the problem, I have a total of 8 codes all transmission related, I think it might be in the wiring harness? not sure, but I thought I would update in case someone else has the same problem or any ideas
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2376134
09/24/17 11:10 PM
09/24/17 11:10 PM
birdtracker Offline
birdtracker  Offline
whats the fault codes? Birdtracker
Re: 2006 dakota pcm question [Re: birdtracker] #2376158
09/25/17 12:03 AM
09/25/17 12:03 AM
pacific northwest
pacific northwest
PO700, 846, 871,988,876, 882, currently checking all connections/ grounds and the wiring the best I can
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2393087
10/25/17 09:39 PM
10/25/17 09:39 PM
pacific northwest
pacific northwest
only one code P0882 TCM power signal low, apparently the PCM is getting power to it but not sending it out to the trans relay,
I will post next update, any ideas Im all ears
Re: 2006 dakota pcm question [Re: Stroker Scamp] #2433089
01/11/18 10:33 PM
01/11/18 10:33 PM
pacific northwest
pacific northwest
Figured I would update we ran another relay to bypass old one, Now intermittently will throw a code of P0883 High voltage instead of low.
Check engine light will be on, sometimes the trans will act up but if we shut it off and restart it drives fine. Hate gremlins!!
