Coning along #2432467
01/10/18 09:49 PM
01/10/18 09:49 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
It is taking longer than I wanted, but with help from Chris (440pursuit) it is closer now to being done.
fron.jpg.e45f6cf48226f7a2565f77c27724851d.jpgmotor.jpg.ca0ec3ccd7d78b80b2537697f5851a78.jpgside.jpg.e8a3598bdc236c1e4473906ce61774e6.jpg
Coming soon!!!!
Re: Coning along [Re: Mr.Yuck] #2432470
01/10/18 09:53 PM
01/10/18 09:53 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Looking good! What’s the combo?
Re: Coning along [Re: humpty] #2432500
01/10/18 10:46 PM
01/10/18 10:46 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
512 LD, with heavily modified Stage VI heads, 630ish cam, Modified Indy 440 intake, built 727 w/ brake, 3800-4k stall, back halved 4 link car, full cage, 4.56 33x19.5's
Re: Coning along [Re: Mr.Yuck] #2432541
01/10/18 11:45 PM
01/10/18 11:45 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
What's your goal for this build
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Coning along [Re: 67mprfan] #2432554
01/11/18 12:18 AM
01/11/18 12:18 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
go out and have fun. Should run low 10's when all is right
Re: Coning along [Re: Mr.Yuck] #2432570
01/11/18 12:37 AM
01/11/18 12:37 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Lookin Good
Re: Coning along [Re: Mr.Yuck] #2432577
01/11/18 12:47 AM
01/11/18 12:47 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nice
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Coning along [Re: Mr.Yuck] #2432611
01/11/18 01:51 AM
01/11/18 01:51 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
LIKE!!!! up
Re: Coning along [Re: Mr.Yuck] #2432616
01/11/18 02:03 AM
01/11/18 02:03 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You know all the epoxy in those runners means your fuel needs to be absolutely alcohol-free, right?
I wonder who added the raised ridges in the port floors... they weren't there when those heads were done originally.
Re: Coning along [Re: Mr.Yuck] #2432629
01/11/18 02:28 AM
01/11/18 02:28 AM
Ohio
lockjaw-express Offline
Ohio
Nice Paint!
Looks like it will be a fun car at the track!
Mark
Re: Coning along [Re: Mr.Yuck] #2432636
01/11/18 02:37 AM
01/11/18 02:37 AM
Puyallup, WA
Puyallup, WA
I assume the intake runners match the ridges in the port floors. Can anyone school me on this theory? I assume it has to do with splitting the intake charge to minimize the obstruction of the valve stem and guide (?). I’ve never seen this before.
Re: Coning along [Re: Mr.Yuck] #2432649
01/11/18 02:58 AM
01/11/18 02:58 AM
Superfreak
Superfreak
I think you got a great deal on that car, looks really good.
Re: Coning along [Re: StealthWedge67] #2432689
01/11/18 08:52 AM
01/11/18 08:52 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'm with you on this one work is this the new modification being done to these heads now?
Re: Coning along [Re: racerx] #2432858
01/11/18 04:17 PM
01/11/18 04:17 PM
BradH Offline
BradH  Offline
One of you should post these questions with that picture on SpeedTalk.com and see what you get for answers.
Re: Coning along [Re: Mr.Yuck] #2432862
01/11/18 04:19 PM
01/11/18 04:19 PM
BradH Offline
BradH  Offline
What's it going to weigh? With 500+ cubes, etc., it should be in the 9s, unless is deceptively heavy or the combination of gearing / converter / whatever isn't a good match.
Re: Coning along [Re: Mr.Yuck] #2433118
01/11/18 11:35 PM
01/11/18 11:35 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
The heads were done because of NHRA rules I believe. The ports have been moved and raised. This is a former members engine. It was designed to run 9's. The car is all steel, so I suspect it will be close to 3200 w/ driver and gas. It could probably run 9's on "pump gas". I'm just going to take it easy....
Coming soon!!!!
Re: Coning along [Re: BradH] #2433212
01/12/18 02:40 AM
01/12/18 02:40 AM
Puyallup, WA
Puyallup, WA
I guess I should check out SpeedTalk.com. Thanks for the tip, Brad.
If it is in fact to shape the charge past the guide boss & valve stem, it seems this mod would be more effective on the port roof than the floor. If the charge follows the port into the bowl, wouldn’t charge following the upper half of the port cross the guide boss & stem, while the floor charge would fall directly across the valve face (???).
Re: Coning along [Re: StealthWedge67] #2433279
01/12/18 11:07 AM
01/12/18 11:07 AM
BradH Offline
BradH  Offline
If it is in fact to shape the charge past the guide boss & valve stem...
It's not.
Re: Coning along [Re: Mr.Yuck] #2433285
01/12/18 11:23 AM
01/12/18 11:23 AM
BradH Offline
BradH  Offline
Quick history lesson:
1. The castings were mine, originally... had an uncommon feature of CNC chambers, although the ports were as cast.
2. Another member bought them and provided them to the group from Moparts that entered the Engine Masters competition... 2003, IIRC. I believe four different people had their hands on those heads to complete the work. The only one who still posts here on any regular basis is Dwayne Porter.
3. Jim Hanrahan "440Jim" bought them and ran them on his A-body bracket car before going "big" with a new engine and switching to E85 fuel. Any alcohol in the fuel will turn all that epoxy to sh!t.
4. I knew Chris bought them, but didn't know if he ever used them.
The last pictures I'd seen of them did not show the additional floor "wing". I don't know if those were used on all of the ports, or only certain ports, or... ? They aren't part of the original epoxy fill to raise the ports.
Re: Coning along [Re: Mr.Yuck] #2433412
01/12/18 03:07 PM
01/12/18 03:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Brad I thohght they looked familiar but could not see a lot of that port. You can clearly see the "wings" are made from a different epoxy as well. Not sure its the "hot ticket". Be interesting to see how it runs..In the end the OP has the right idea. Build it and have fun with it...
