Power Port 240 TF porting results Flow Tech 2 #2432499
01/10/18 10:45 PM
01/10/18 10:45 PM
Granbury TX
Prochargedmopar Offline OP
Granbury TX
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432501
01/10/18 10:48 PM
01/10/18 10:48 PM
Granbury TX
Granbury TX
[img:center]https://www.dropbox.com/s/ymv1bcro6yie4rf/Photo%20Jan%2010%2C%206%2043%2044%20PM.jpg?dl=0[/img]
Not sure whats going on but I can’t seem to add pics any more.
Hmmmmmm
02 Mercedes C230K
19 Camry
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432530
01/10/18 11:28 PM
01/10/18 11:28 PM
Those numbers look good up
Similar to a set of Indy SR M.W heads that I had, not as good as the CNC ported 440-1 I've had whistling grin
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Cab_Burge] #2432539
01/10/18 11:42 PM
01/10/18 11:42 PM
Granbury TX
Granbury TX
It says standard port.
Are the TFs raised port but still can use stock type intakes and Ex. manifolds.
If I was Todd Marsh I would be getting some cnc files saved of Larrys work before he can’t do it any more.
Either that or learning every trick of the trade this guy has to offer over the next X # of years.
02 Mercedes C230K
19 Camry
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432621
01/11/18 02:17 AM
01/11/18 02:17 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I believe he's using checking springs that are too soft for flow bench testing. That would explain the pattern I've seen where all his posted flow tests have abnormally high low-lift intake #s.
Re: Power Port 240 TF porting results Flow Tech 2 [Re: BradH] #2432633
01/11/18 02:33 AM
01/11/18 02:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If that's the case, yes that would back up that opinion.
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432635
01/11/18 02:36 AM
01/11/18 02:36 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Hmmmmmm
Did you use an Apple device to upload the pics?
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Sport440] #2432641
01/11/18 02:42 AM
01/11/18 02:42 AM
BradH Offline
BradH  Offline
The springs shown in the pic of the head on the flow bench are not stiff enough to hold the valve in the set position at low lifts. If they weren't stiff enough on my low-power bench, they're definitely not stiff enough for the bench pictured.
Re: Power Port 240 TF porting results Flow Tech 2 [Re: ccdave] #2432672
01/11/18 05:24 AM
01/11/18 05:24 AM
Granbury TX
Granbury TX
Hmmmmmm
Yes, Iphone 7+
02 Mercedes C230K
19 Camry
Re: Power Port 240 TF porting results Flow Tech 2 [Re: BradH] #2432735
01/11/18 10:25 AM
01/11/18 10:25 AM
The Great White North
RAMM Offline
RAMM  Offline
Could not agree more. One glance at the low lift numbers and...
J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Power Port 240 TF porting results Flow Tech 2 [Re: RAMM] #2432754
01/11/18 12:15 PM
01/11/18 12:15 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I've said it once and I will say it again. Without before and after numbers on the same flowbench there's always that BIG question mark at the end. I understand time is money and BIG numbers gets you more work but I like to do the math myself to judge whether the numbers TRULY stack up. Especially if the head porters bench is still from the "purple shaft age" with liquid manometers. You wouldn't believe how numbers could swing on my old flowbench during an 8 hour day.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432774
01/11/18 01:12 PM
01/11/18 01:12 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That is like the flow that Koffels got from my std port but I have to ask does the gasket match on the corners of the port on yours?
PS:My mistake I have Victors,DUH!SORRY!
Re: Power Port 240 TF porting results Flow Tech 2 [Re: RAMM] #2432825
01/11/18 03:11 PM
01/11/18 03:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
J.Rob
You know there's a problem when the discharge coeffienct is over 100%.
Re: Power Port 240 TF porting results Flow Tech 2 [Re: fast68plymouth] #2432944
01/11/18 06:41 PM
01/11/18 06:41 PM
Granbury TX
Granbury TX
I asked the question you guys presented as it got me curious.
“I post your pics and results sometimes on Moparts or other forums.
Most say your low lift #’s are too high and the consensus between keyboard warriors is your checking springs are too weak to hold the valve at low lift.
Any truth to this?
Thanks” (Pro)
I got an answer;
“Floating the valves on the flow bench lol, I use the same checking springs for last 30 years, I check for vacuum leaks when I flow test, I got flow sheets for 36 years I had high numbers then, porting heads for round track engines you learn where to keep the flow up for torque, if I where to post my p7 and p8 heads for the dodge NASCAR engine they think they where hemi heads, those heads spoke for theirself making 950 plus HP and hold it up to 10,000 RPM, I'm fooling myself to post unreal numbers”
(Flow tech 2)
https://www.facebook.com/permalink.php?story_fbid=1218287181637121&id=503146179817895
02 Mercedes C230K
19 Camry
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432953
01/11/18 06:52 PM
01/11/18 06:52 PM
AndyF Offline
AndyF  Offline
Classic response.
If you really want to know what is going on with those heads you'll have to send them to Dwayne and have him flow them on his bench. Then you'll have numbers that you can use for comparison.
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432954
01/11/18 06:54 PM
01/11/18 06:54 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
ask him what the out of the box numbers were?
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432958
01/11/18 06:58 PM
01/11/18 06:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
Still doesn't explain how you end up with c/d numbers over 100%(and to get 100% efficiency it's air flowing through a perfectly straight unrestricted piece of tubing. Not air making turns around guides and valves and through valve seats).
It can't be better than 100%.
Most heads with 45deg seats, with a valve job and throat diameter/shape designed to provide good low lift flow will have c/d numbers from .100-.300 lift in the 70-75% range.
That head might very well flow 352@.700 lift.
It doesn't flow 104@.100 lift.
The thing to keep in mind with flow results are, the head flows what it flows.
If you have it tested on 10 benches and get 10 different results, the fact is...... The head still actually flows the same on every bench(if the same test pressure is used).
However, Some of the results will be more accurate than others.
I'd happily flow one of those heads from Larry for free...... Just pay the shipping.
Preferably one that was already flowed and you had numbers on it.
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432973
01/11/18 07:33 PM
01/11/18 07:33 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Hmmmmmm
Yes, Iphone 7+
Moparts does not play nice with Iphones... Problem with UBB Threads.
Exhausting..
Re: Power Port 240 TF porting results Flow Tech 2 [Re: fast68plymouth] #2432979
01/11/18 07:48 PM
01/11/18 07:48 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You already flowed one and your numbers were better than his. Go look at the BB Sidewinder data. Your low lift numbers were better than his. His bigger numbers were better. IN BOTH OF YOUR defense that was your first crack at them and BOTH of you were trying things out for the first time. I bought the Superflow 1080 bench from Larry Wallace racing where Larry used to work. Hope to have it operational very soon. In the paper work when I got it there were notebooks full of THOUSANDS of P7 head tests they did for the top team in NASCAR. Reading through them is staggering. They spent MILLIONS getting all this data. Larry was the Head porter. Roger Penske could afford any body he wanted and he picked Larry. I have had Larry do hundreds of heads and I can say his only mistake is usually doing more work than was required and that takes time that he does not get paid for.
Todd
Re: Power Port 240 TF porting results Flow Tech 2 [Re: Prochargedmopar] #2432980
01/11/18 07:52 PM
01/11/18 07:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
That's all fine......... But it can't exceed 100% c/d.
It's that simple.
If you have a c/d number over 100%, there's a calibration issue or a leak. End of story.
I have a 100cfm calibrated test plate, so I could take the calibration of my bench right out of the equation to see if that head flows 104cfm@.100 or not.
It either flows more than the 100cfm test plate, or it doesn't.
I'm saying it will probably be +/- 20% less than that plate.
The reason for the focus on the .100 flow is, it's so easy to spot when it's that far off(20-25%).
Then, once you know that number is wrong, the rest of the numbers are called into question.
If that head flowed 104@.100 lift on my bench I'd be the first one to take my hat off to Larry on a job well done and eat my words on calling into question the validity of his numbers.
