Re: rockers for victor max wedge heads
[Re: BradH]
#2431160
01/08/18 05:42 PM
01/08/18 05:42 PM
BradH
... Hughes only has one version, which they used to specify as .600" offset, but I don't know if it's even that much (I think its only .550" now) since they redesigned them. Earlier style is the "solid body" intake shown on the left, with the redesigned rockers shown on both exhausts and the intake on the right.
[Re: rbkt65]
#2431175
01/08/18 06:25 PM
01/08/18 06:25 PM
Posts: 1,113 Usa
A39Coronet
Usa
I have standard port Victor's which would take the same rockers, and I've been using Hughes since day one. Non-cryo treated, 420lb open spring pressure Mine are the early "solid body" design.
[Re: Jeremiah]
#2431514
01/09/18 10:35 AM
01/09/18 10:35 AM
Posts: 287 PA
Harry's Taxi 2
PA
I have a set of non-cryo Hughes on my Victor MW 511. They survived over 20 dyno pulls several of which were on nitrous making over 900hp. Bodies look good, rollers roll fine, no shaft galling. 240ish closed, 740ish open for spring pressures.
To get everything where it needed to be geometry wise it used B3R Racing's geometry correction kit. It worked well and setting up the valve train was very repeatable once we installed head stud insert washers into the shafts.
Pulled really good way past 7000 and idled like a 509 purple monster lol. Could you explain or show a picture of the head stud insert washers you mentioned above?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
