rockers for victor max wedge heads #2431129
01/08/18 04:26 PM
01/08/18 04:26 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
I have a partial set of procomps left. not buying those again if I reuse my victors. see hughes,440 source have them can not afford hs. what is next level?
Re: rockers for victor max wedge heads [Re: rbkt65] #2431154
01/08/18 05:28 PM
01/08/18 05:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My OPINION:
1. Jesel... $$$$
2. T&D... $$$
3. Harland Sharp... $$$
4. Hughes... $$
5. ???
Sorry, I won't even include Procomp or 440 Source rockers in this list.
I don't think ANY of the above rockers are a great match for BB Victor heads, in part due to the Victors themselves. And the Jesels are far from "bolt on", which means they're really in a different price range than the others w/ the additional machine work required.
T&D offers MW-specific and standard-port-specific Victor rockers (different intake offsets). Hughes only has one version, which they used to specify as .600" offset, but I don't know if it's even that much (I think its only .550" now) since they redesigned them.
Victor owners get hind teet on rocker choices, IMO.
Re: rockers for victor max wedge heads [Re: BradH] #2431160
01/08/18 05:42 PM
01/08/18 05:42 PM
BradH Offline
BradH  Offline
Originally Posted By BradH
... Hughes only has one version, which they used to specify as .600" offset, but I don't know if it's even that much (I think its only .550" now) since they redesigned them.
Earlier style is the "solid body" intake shown on the left, with the redesigned rockers shown on both exhausts and the intake on the right.
Re: rockers for victor max wedge heads [Re: rbkt65] #2431175
01/08/18 06:25 PM
01/08/18 06:25 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I have standard port Victor's which would take the same rockers, and I've been using Hughes since day one. Non-cryo treated, 420lb open spring pressure Mine are the early "solid body" design.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: rockers for victor max wedge heads [Re: A39Coronet] #2431370
01/08/18 11:50 PM
01/08/18 11:50 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have a set of non-cryo Hughes on my Victor MW 511. They survived over 20 dyno pulls several of which were on nitrous making over 900hp. Bodies look good, rollers roll fine, no shaft galling. 240ish closed, 740ish open for spring pressures.
To get everything where it needed to be geometry wise it used B3R Racing's geometry correction kit. It worked well and setting up the valve train was very repeatable once we installed head stud insert washers into the shafts.
Pulled really good way past 7000 and idled like a 509 purple monster lol.
Re: rockers for victor max wedge heads [Re: rbkt65] #2431377
01/09/18 12:11 AM
01/09/18 12:11 AM
You have a PM on this scope
Re: rockers for victor max wedge heads [Re: Jeremiah] #2431514
01/09/18 10:35 AM
01/09/18 10:35 AM
PA
Harry's Taxi 2 Offline
PA
Could you explain or show a picture of the head stud insert washers you mentioned above?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: rockers for victor max wedge heads [Re: rbkt65] #2431535
01/09/18 12:05 PM
01/09/18 12:05 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I used the HS rockers and just bolted them on without any geometry changes. They offer 2 different lenghts and i believe i have the shorter version. May have been why some had trouble with geometry when using these. Great company. I bought thru Don at FBO and communicated with HS directly.
