HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI #243093
03/04/09 06:06 PM
03/04/09 06:06 PM
st.charles,mo.
dodgem1 Offline OP
dodgem1  Offline OP
st.charles,mo.
help,im restoring the dash on my 69 r-r-ive have used krylon semi flat,its too shiny,has anyone done this with success-should i use flat-help
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: dodgem1] #243094
03/04/09 07:34 PM
03/04/09 07:34 PM
MO
cdp Offline
cdp  Offline
MO
The original finish is a textured finish called Jewel Black. I ordered a quart of Lacquer from TCB Global for an OEM resto.
If you want to stick to a rattle can, you could order a correct finish from Totally Auto.
Or just test out a section on the dash with flat.
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: dodgem1] #243095
03/04/09 08:21 PM
03/04/09 08:21 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Just did mine. The right stuff is Ditzler 9324. PPG was able to do me a quart in laquer for about $90. It's called suede finish.
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: Silverbullet2] #243096
03/05/09 01:21 PM
03/05/09 01:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've painted probably a dozen dashes with the suede texture, now I have them powder coated, the finish is a perfect match for the suede & it's much more durable....
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: 1_WILD_RT] #243097
03/05/09 01:39 PM
03/05/09 01:39 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
Guys,how much paint would be needed to do an interior on a 66 satellite?I guess you only need enough suede for the dash and steering column,the bucket seat backs and doors are a different shade again thats duller than the exterior but shinier than the dash,right?
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: 1_WILD_RT] #243098
03/05/09 02:14 PM
03/05/09 02:14 PM
runningman Offline
super street
runningman  Offline
super street
Which powder do you use that is a good match? I would like to get mine done as well. Thanks
Matt
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: ogopogo] #243099
03/05/09 02:16 PM
03/05/09 02:16 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
The bucket seat backs are something TOTALY different ....
DO NOT STRIP them, just dye them and deal with the scratches. The jewel black does not look right at all for this application (don't ask someone told me it was the same, so I stripped mine, and now they look like crap).
The orig paint was some rubber paint with a vinal/leather texture to it.
RAR II
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: 6T6Cuda] #243100
03/05/09 03:08 PM
03/05/09 03:08 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
I have played and am playing with this a lot. If you are going to rattle can it, Duplicolor flat black ends up looking exceptionally nice. Only the dash and steering column though. The rest of my interior, while originally black was not the same type of paint or finish. You can pay a lot to get the absolute correct finish or a little and get something that is looks real nice. Also, I have tried clearing over satin, flat, and semi-gloss with really bad results. Nobody makes a clear flat in a can that I can find. Clearing(satin) over flat did some real strange stuff producing a hazing affect. It is your car. spend your $$ where you want but for me, the flat black rattle can actually came out looking nicer that the dash did from the factory.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: klunick] #243101
03/05/09 03:19 PM
03/05/09 03:19 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
ordered mine from kolor korrect,qt is 85.00,but is perfect,don't forget to do your ashtray at the same time. good luck,kolor korrect also has the vinyl paint for seat back,like said don't strip you first spray with bulldog adhesive then your color,and it won't scratch good luck
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: runningman] #243102
03/05/09 08:27 PM
03/05/09 08:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Matt
I wish I could tell you, the guy I had do it has gone out of business, I do know it was a Tiger Drylaq product, I've posted that image before & people have printed it out & shown it to their powdercoater & had it matched....
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: ogopogo] #243103
03/05/09 10:44 PM
03/05/09 10:44 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Wrong. The 66 B-body steering column and interior doors are a full gloss finish. The doors get dull because nobody ever polishes or washes the interior doors. Don't believe it? Go to a car with original paint on the interior doors, wash it, dry it, then polish it, you will see a high gloss finish.
The seat backs and side trim are a vinyl coating like said above.
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: NANKET] #243104
03/05/09 11:56 PM
03/05/09 11:56 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
Every car I've owned has had high gloss paint on painted door/trim panels. Most dashes are suede, but not all. My 65/66 Chryslers have a gloss dash.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: HELP-PAINTING DASH 1969 R-R-WHAT COLOR-NOT KRYLON SEMI [Re: 1_WILD_RT] #243105
03/06/09 05:04 AM
03/06/09 05:04 AM
runningman Offline
super street
runningman  Offline
super street
Thanks!
