Stock Rocker Arm Questions - Big Block
#2430533
01/07/18 03:27 PM
01/07/18 03:27 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
I've seen stock iron heads that have "wide" rocker stands (top pic) & "narrow, machined" rocker stands (bottom pick).
1. Do any year stock rockers/shafts fit on either style of rocker stands? 2. What are some decent quality aftermarket, stock-style rockers that aren't too expensive?
THANK YOU!
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: Stock Rocker Arm Questions - Big Block
[Re: PurpleBeeper]
#2430840
01/08/18 12:19 AM
01/08/18 12:19 AM
Posts: 7,664 IN
ahy
IN
Stock steel rockers for FT hydraulic cam - like the ones linked below - will fit stock and stock replacement heads. Generally good to .5" lift and matching springs. I do not think width of the pedestals matters but not sure. Can you share some specifics on your heads, cam and combo? http://www.manciniracing.com/mararoarmset1.html
[Re: PurpleBeeper]
#2430865
01/08/18 01:11 AM
01/08/18 01:11 AM
Posts: 43,172 Bend,OR USA
Cab_Burge
Measure the widths of the stands on both sets of heads and compare the widths and go from there As far as what is decent quality rocker arms and shafts it depends on what your going to use them for and the cam lift and RPM Tell us a little more info on your build and intended use so we can help you and not mislead you down the wrong path BTW, the stock stamped steel rocker arms can vary in the ratio from 1.38 to 1.52, depending on how much wear and which vendor supply the rockers that year
[Re: ahy]
#2431126
01/08/18 04:18 PM
01/08/18 04:18 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
Stock steel rockers for FT hydraulic cam - like the ones linked below - will fit stock and stock replacement heads. Generally good to .5" lift and matching springs. I do not think width of the pedestals matters but not sure. Can you share some specifics on your heads, cam and combo? http://www.manciniracing.com/mararoarmset1.html I haven't got the heads yet, but I'm building a close-to-stock 2nd engine for my car on a budget. I plan to run iron heads (452's or similar unleaded-friendly seats), open chamber, and the stock (or stock-style) non-adjustable rockers & a .470"-.480" lift range cam (just larger than stock).... think "Hemi-grind" purple shaft. The reason I ask is that on my current motor, I have the "wider", non-machined rocker stands ('71 heads I believe/top picture) and when I put on Isky adjustable rockers, I had to take a file to the rocker stands for clearance to get the rockers to line up over the valves properly. I'm just wondering if I'd run into a problem with stock rockers if I buy the heads from one guy and rockers/shafts from someone else. I haven't run non-adjustable rockers arms in 20+ yrs., so I really don't know.
[Re: PurpleBeeper]
#2431247
01/08/18 08:48 PM
01/08/18 08:48 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I went with
Sealed Power R - 828 Sealed Power R - 829
Sealed Power Shaft RS - 612
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
