Indy block repair. Thinking out of the box.
#2430624
01/07/18 06:18 PM
01/07/18 06:18 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
So, I have a solid RB IndyMax block. At some time, it broke a rod, windowed the drivers side and also tagged #2 sleeve. I found a hole next to the sleeve that I think is the front to back oil galley that runs alongside the lifter bores. You can see a crack in the pics that shows the hole. Pete at Barton said that they don't want to touch it. They have actually repaired this type of damage before, but that "The engine wasn't right". He didn't elaborate on what he meant by that, but they tried to sell me a new engine block, if I could just give them some time to get them (Ha-ha!).
The lifters are not oil fed, but by Mopar guides, the passenger oil galley feeds the main bearings. So cutting out the damage and running pipe plugs into the ports is out. I was thinking of running a metal sleeve through the inside and JB weld it into place, along with as tight a press fit as I could reasonably get. I could plug both sides of the damaged area, and then run a crossover oil feed from the top side between the left and right oil galleys.
I'm trying to avoid a welding repair, because it will probably cause some block distortion at the cam bearing journals. The block is already sized for 55mm roller bearings, so I don't know how much room I have to correct a misalignment issue.
Re: Indy block repair. Thinking out of the box.
[Re: sgcuda]
#2430636
01/07/18 06:32 PM
01/07/18 06:32 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I’d say you’re on the right track with tubing the galley. Welding makes everything move around and softens the material. I would go with tube and run it.
[Re: TRENDZ]
#2430639
01/07/18 06:38 PM
01/07/18 06:38 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I personally would get a die grinder in there and slowly grind out all the bad stuff first and then get a better eye in there with the mess gone. I too would rather not start welding in there unless I had too.
[Re: sgcuda]
#2430641
01/07/18 06:43 PM
01/07/18 06:43 PM
sgcuda
I have to come up with something to pull the sleeve out. That would allow a much better view of the damage. All of the sleeves are going to be replaced anyway.
[image][/image]
[Re: The Shadow]
#2430683
01/07/18 08:17 PM
01/07/18 08:17 PM
sgcuda
How are you planning on fixing the drivers side window without welding Window was previously repaired. If I can get the oil galley fixed, it will just need sleeves and decking. Oh, does anyone have a set of main cap hardware for sale? Block came with caps, but no studs, washers, nuts, crossbolts.
[Re: sgcuda]
#2431150
01/08/18 05:16 PM
01/08/18 05:16 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Indy sleeves are tough MOFO's to remove for sure
[Re: sgcuda]
#2431236
01/08/18 08:30 PM
01/08/18 08:30 PM
Posts: 4,274 Morrow, OH
markz528
Morrow, OH
What about welding a few beads in the sleeve all the way around to draw them in some? I use that technique on antifriction bearings when they don't want to come out and after the welding bead they pop right out,
[Re: markz528]
#2431259
01/08/18 08:58 PM
01/08/18 08:58 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
What about welding a few beads in the sleeve all the way around to draw them in some? I use that technique on antifriction bearings when they don't want to come out and after the welding bead they pop right out, Yep. This is what I do to get sleeves out of diesel engines Run the welds straight up and down like a piston travels
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
