Installing New E-Brocks on SB #242870
03/04/09 02:08 PM
03/04/09 02:08 PM
Nelsonville , Ohio
Duster3105 Offline OP
Nelsonville , Ohio
I pick up my new heads Friday @ Jeg's.
I know they recommend their bolt set, so I'm getting them too.
I have read a few of the post re: head gaskets and which one's some of you prefer or seem to work better.
Is there any surprises relating to the intake gaskets? I run a torquer II 340 intake.
These heads are going on the engine I've ran the last 5 years. New bearings, rings, checked wear,cam & lifter change, adjustable rockers, etc....
Any other surprises I might encounter?
Oh yea, we are just doing a small pocket port, debur and smooth up the ports this year.
Thanks / Rick....
Re: Installing New E-Brocks on SB [Re: Duster3105] #242871
03/04/09 03:26 PM
03/04/09 03:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I don't remember the gasket part numbers, but they are in the literature that comes with them. Also, just remember to retorque the heads a few times after getting them up to temp....And if your serious about keeping the hp the same as if they were cast iron, call Swain Tech coatings after you port them. Well worth it.
Re: Installing New E-Brocks on SB [Re: Dragula] #242872
03/04/09 04:45 PM
03/04/09 04:45 PM
Nelsonville , Ohio
Nelsonville , Ohio
[ call Swain Tech coatings after you port them. Well worth it.
Can you explain this to me, is it they won't keep any profile after smoothed? Not trying to sound stupid, but have never had aluminum heads before.
Thanks for your help.
Rick....
Re: Installing New E-Brocks on SB [Re: Duster3105] #242873
03/04/09 04:57 PM
03/04/09 04:57 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
The sheet says 1008 felpros or the edlebrock gaskets eldebrock now sells their own as head or whole head sets.
I asked here if it would be ok to use the cheaper 8553 felpros and they most said no.
I got the ARP Bolts for mine.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Installing New E-Brocks on SB [Re: Duster3105] #242874
03/04/09 05:58 PM
03/04/09 05:58 PM
Excellent upgrade for your 340,the gaskets needed are felpro 1008's,a mlid port job will get those head flowing just fine and will perform great,i've been running a pair on my 416/360 motors for 3 years now with great results...
Re: Installing New E-Brocks on SB #242875
03/04/09 06:05 PM
03/04/09 06:05 PM
340SIX Offline
340SIX  Offline
The edlebrocks #7326 are cheaper than the felpro 1008
If he is at Jegs he should at least look them over if they stock them.
Full Kit intake,exhasut,heads #7370
Re: Installing New E-Brocks on SB [Re: Duster3105] #242876
03/04/09 06:37 PM
03/04/09 06:37 PM
Dragula Offline
Dragula  Offline
Rick....
They explain it on their site, but basically having the heads done after porting will raise hp anywhere from 3%-5% and sometimes a little more.
That's 4-5hp for every hundred hp you have, and it helps keep engine temp down.
http://www.swaintech.com/store.asp?pid=10296
"Peak horsepower was up 2% from 318 to 324 horsepower and peak torque was up 5% from 320 lb/ft to 335 lb/ft. In the heart of the curves, these numbers were even more impressive. At 4,500 rpm, torque was up 7% from 298 lb/ft to 319 lb/ft. At 5,500 rpm, horsepower was up 6% from 302 to 320 horsepower. Most engine builders will take full advantage of the coating by making jetting (or computer), timing, and lighter weight oil for maximum power gains. However for this test, we wanted to document and publish the gains that are achieved if the only modification was coating the engine. If the proper tuning adjustments were made to take full advantage of the coatings, these results would have been even more impressive."
Re: Installing New E-Brocks on SB [Re: Duster3105] #242877
03/04/09 08:52 PM
03/04/09 08:52 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: Installing New E-Brocks on SB [Re: S/ST 3040] #242878
03/04/09 11:35 PM
03/04/09 11:35 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
nice pics s/st3040 car looks good
Re: Installing New E-Brocks on SB [Re: one bad fish] #242879
03/05/09 04:36 AM
03/05/09 04:36 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I used the cheap fel-pro on a street 340 with e-brocks and a 150 shot of nos with good result.
Re: Installing New E-Brocks on SB [Re: sshemi] #242880
03/05/09 09:41 AM
03/05/09 09:41 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
One surprise you might have is the alternator won't fit. The eddie heads stick out further sometimes causing interference with the alternator. This is especially true on the '69 and earlier cars with the shorter water pumps because the alternator is closer to the head in those cases.
Re: Installing New E-Brocks on SB [Re: 69Cuda340S] #242881
03/05/09 02:01 PM
03/05/09 02:01 PM
Nelsonville , Ohio
Nelsonville , Ohio
I'm running the later model water pump, so hopefully I won't have that problem.
Thanks for all of your input & help!
Rick.......
Re: Installing New E-Brocks on SB [Re: 69Cuda340S] #242882
03/06/09 12:52 AM
03/06/09 12:52 AM
340SIX Offline
340SIX  Offline
The factory lenth spacer that goes between the head and alt was to long I had to cut some off for the Comandos. So I figuered theEdlebrocks would be the same
Re: Installing New E-Brocks on SB [Re: 340SIX] #242883
03/06/09 08:53 AM
03/06/09 08:53 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Be careful bolting the intake on, the small block Eddy heads I bought years ago had threaded holes as soft as butter, had to heli-coil all of them.
Re: Installing New E-Brocks on SB [Re: ProSport] #242884
03/06/09 09:11 PM
03/06/09 09:11 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Hey Rick, You wont have a problem with the alternator fitting with the newer style water pump, mine fit just fine with no alterations. Prosport, mine came with all holes heli-coiled. Good luck and see you soon
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Installing New E-Brocks on SB [Re: G-Money1320] #242885
03/06/09 10:54 PM
03/06/09 10:54 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Good, glad they fixed that problem cuz it was a real pain.
Re: Installing New E-Brocks on SB [Re: G-Money1320] #242886
03/06/09 11:11 PM
03/06/09 11:11 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Thats right, the '70 up aluminum pumps are thicker and move the alternator forward and away from the head. You still might need to use a "round back" type alternator to get it to clear.
Re: Installing New E-Brocks on SB [Re: G-Money1320] #242887
03/09/09 02:45 PM
03/09/09 02:45 PM
Nelsonville , Ohio
Nelsonville , Ohio
You're right Greg, I mocked everything up and seems to fit fine.
Got one head completed, will do the other when I get in on Thursday, then off to the machine shop to double check valve seats on Friday.
I have learned one important lesson, the aluminum cuts WAY quicker with the porting tool than the cast ones did. But smooths up nicely with the emery cloth .
Thanks for everyones help.
Rick....
