Exhaust size for 5.7 #2427941
01/02/18 08:15 PM
01/02/18 08:15 PM
Wooster, Ohio
K
kpzbee Offline OP
kpzbee  Offline OP
K
Wooster, Ohio
I'm doing a Eagle swap into mt '73 AMC Javelin and am currently looking at how to route exhaust under it before I finish up my trans tunnel. I'm using OE SRT shorties and they measure 2.75" ID. Would 2.5" be adequate or should I go 3" back to the mufflers and 2.5 tailpipes? I'm going to have to use oval pipe since clearance is an issue. This is a street driver used for long hauls so wringing every bit of hp is not my main concern. Thoughts? Suggestions? Thanks.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
Re: Exhaust size for 5.7 [Re: kpzbee] #2427960
01/02/18 09:00 PM
01/02/18 09:00 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Im a min 3" guy. I would put 3" on a lawnmower
Re: Exhaust size for 5.7 [Re: kpzbee] #2428010
01/02/18 10:21 PM
01/02/18 10:21 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If you're staying with stock manifolds, I would leave it as 2.5".
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Exhaust size for 5.7 [Re: kpzbee] #2428024
01/02/18 10:48 PM
01/02/18 10:48 PM
Australia
aus370 Offline
aus370  Offline
Australia
I'd do the 3.0 to the muffs , then 2.5 after that , and put some straight through offset muffs in the tail pipes if you want it a little quieter .
And some sort of balance pipe is a must , but that's just my opinion .
Re: Exhaust size for 5.7 [Re: kpzbee] #2428198
01/03/18 10:34 AM
01/03/18 10:34 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
My .02 is 2.5in with an X-pipe 2.5in tail pipe,
3in no X-pipe, 2.5 tail pipe
Re: Exhaust size for 5.7 [Re: kpzbee] #2428762
01/04/18 09:58 AM
01/04/18 09:58 AM
Wooster, Ohio
K
kpzbee Offline OP
kpzbee  Offline OP
K
Wooster, Ohio
Thanks for the opinions. I'm going to go with 2.5" X pipe system. Getting 2.5" tailpipes in there is going to be tuff but it will happen somehow.
Re: Exhaust size for 5.7 [Re: kpzbee] #2428994
01/04/18 05:46 PM
01/04/18 05:46 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How well do the SRT shorties fit?
Re: Exhaust size for 5.7 [Re: WO23Coronet] #2429368
01/05/18 10:06 AM
01/05/18 10:06 AM
Wooster, Ohio
K
kpzbee Offline OP
kpzbee  Offline OP
K
Wooster, Ohio
The right side fits perfect but the left is hitting the starter. The car version swings away from the block further so I have a pair of those on the way to see if that will work. I'm trying to avoid the cost of special headers. I'm having to use a 4L60E trans so there's an adapter in it and it makes the starter stick out slightly further than it did on the 518. frown I couldn't get the 518 to fit in the tunnel with the Hemi like it did with the Magnum I had in it.
I picked up a 3' length of 2.5" pipe yesterday and with some drive shaft tunnel "massaging" it will fit, abet very tight. A tight X pipe should fit right behind the X member.
