#2427941 - 01/02/18 05:15 PM Exhaust size for 5.7
kpzbee Offline
Loc: Wooster, Ohio
I'm doing a Eagle swap into mt '73 AMC Javelin and am currently looking at how to route exhaust under it before I finish up my trans tunnel. I'm using OE SRT shorties and they measure 2.75" ID. Would 2.5" be adequate or should I go 3" back to the mufflers and 2.5 tailpipes? I'm going to have to use oval pipe since clearance is an issue. This is a street driver used for long hauls so wringing every bit of hp is not my main concern. Thoughts? Suggestions? Thanks.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
#2427960 - 01/02/18 06:00 PM Re: Exhaust size for 5.7 [Re: kpzbee]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
Im a min 3" guy. I would put 3" on a lawnmower
#2428010 - 01/02/18 07:21 PM Re: Exhaust size for 5.7 [Re: kpzbee]
GoodysGotaCuda Online   penguin-006
5.7L Hemi, 6spd
Loc: Texas
If you're staying with stock manifolds, I would leave it as 2.5".
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2428024 - 01/02/18 07:48 PM Re: Exhaust size for 5.7 [Re: kpzbee]
aus370 Offline
Loc: Australia
I'd do the 3.0 to the muffs , then 2.5 after that , and put some straight through offset muffs in the tail pipes if you want it a little quieter .
And some sort of balance pipe is a must , but that's just my opinion .
Edited by aus370 (01/02/18 07:54 PM)
Stock 6.1 Hemi . 11.657 @ 113.54 , 3588 lbs.
Sweet on the street , a bit dull on the track .
#2428198 - 01/03/18 07:34 AM Re: Exhaust size for 5.7 [Re: kpzbee]
ric3xrt Offline
Loc: Trumbauersville PA
My .02 is 2.5in with an X-pipe 2.5in tail pipe,
3in no X-pipe, 2.5 tail pipe
#2428762 - 01/04/18 06:58 AM Re: Exhaust size for 5.7 [Re: kpzbee]
kpzbee Offline
Loc: Wooster, Ohio
Thanks for the opinions. I'm going to go with 2.5" X pipe system. Getting 2.5" tailpipes in there is going to be tuff but it will happen somehow.
#2428994 - 01/04/18 02:46 PM Re: Exhaust size for 5.7 [Re: kpzbee]
WO23Coronet Offline
Loc: Canada
How well do the SRT shorties fit?
#2429368 - 01/05/18 07:06 AM Re: Exhaust size for 5.7 [Re: WO23Coronet]
kpzbee Offline
Loc: Wooster, Ohio
The right side fits perfect but the left is hitting the starter. The car version swings away from the block further so I have a pair of those on the way to see if that will work. I'm trying to avoid the cost of special headers. I'm having to use a 4L60E trans so there's an adapter in it and it makes the starter stick out slightly further than it did on the 518. frown I couldn't get the 518 to fit in the tunnel with the Hemi like it did with the Magnum I had in it.
I picked up a 3' length of 2.5" pipe yesterday and with some drive shaft tunnel "massaging" it will fit, abet very tight. A tight X pipe should fit right behind the X member.
25,495 Registered Members
193,153 Topics
Place your bets - Freeze Plugs on the Dart
by GoodysGotaCuda
09/25/18 07:02 PM
1971 Hemi Plymouth Roadrunner WIW
by cudascooter
09/25/18 06:40 PM
1970 steering columns
by Nick Stevanovski
09/25/18 06:39 PM
1970 Challenger Inner Fender
by jim6346
09/25/18 05:01 PM
