lexan #2427235
01/01/18 05:07 PM
01/01/18 05:07 PM
ma.
roadrunner34 Offline OP
ma.
I would like to change front and rear glass over to lexan. Curious as to what company,thickness etc is the better and how much weight was removed.
Re: lexan [Re: roadrunner34] #2427236
01/01/18 05:09 PM
01/01/18 05:09 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Couple questions what car and is the glass that's in the car the OEM glass or has it been replaced
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: lexan [Re: roadrunner34] #2427246
01/01/18 05:20 PM
01/01/18 05:20 PM
ma.
ma.
69 B body with original glass.
Re: lexan [Re: roadrunner34] #2427250
01/01/18 05:23 PM
01/01/18 05:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pro Glass is who I have used and been very happy with..I have used their molded windshields on a few cars.
Re: lexan [Re: Al_Alguire] #2427308
01/01/18 06:49 PM
01/01/18 06:49 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I just did a 68 A body. Original glass.. total savings not using the rubber or the stainless trim.. was 27lb in the front 23lb in the rear. And that was going back with 3/16.. Mar resistant
Re: lexan [Re: WHITEDART] #2427314
01/01/18 06:53 PM
01/01/18 06:53 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
So I guess around 50lb total.. a lot of the replacement glass was lighter.. all that rubber and crap is heavy.. and it all adds up up
Re: lexan [Re: WHITEDART] #2427321
01/01/18 07:07 PM
01/01/18 07:07 PM
fullmetaljacket Offline
Rear and side glass can get away with 1/8 thickness, but if used up front, a brace of some sought needs to be introduced or else it can cave in at speed. 3/16 is usually good to go for the front and still weighs less than original stuff.
Re: lexan [Re: roadrunner34] #2427415
01/01/18 09:45 PM
01/01/18 09:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have mad respect for you guys going through these extra miniscule steps to save ounces in a modification.It's just above and beyond what I am willing to do to save an ounce,,,,,,,,or an 1/8.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: lexan [Re: hemi-itis] #2427425
01/01/18 10:11 PM
01/01/18 10:11 PM
I also question my madness with ounce counts, but in this case, it's literally about pounds and a good amount of it on the front half of the car. Glass can weigh a ton depending on how much of it is incorporated into the design of the car.
Re: lexan [Re: hemi-itis] #2427427
01/01/18 10:12 PM
01/01/18 10:12 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
50 lbs is more than an once or two but I'm going to an after market windsheild. In my class if you have an Lexan windshield they add 150 lbs to your minimum.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: lexan [Re: roadrunner34] #2427436
01/01/18 10:32 PM
01/01/18 10:32 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
When my 69 GTX was apart I weight the front and rear glass. They are right at 30 lbs each.
I am thinking I may have to resort to Lexan if my 8.99 doesn't come around. I will go with 1/4 inch so I can re use my factory trim.
Re: lexan [Re: roadrunner34] #2427471
01/01/18 11:40 PM
01/01/18 11:40 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
After 2 lexan windsheilds, I've opted for after market front glass windshields, a savings of 5 lbs over the factory. Glass is easy to clean and never a bulls-eye issue as with lexan. 1/8" for the rear and 3/16 for the sides if you want the roll up option.
Re: lexan [Re: roadrunner34] #2427614
01/02/18 07:31 AM
01/02/18 07:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My doors are gutted and regulators are removed. Side glass and rear are all 1/8" Lexan. Door windows move with straps. Vents are 1/4" Lexan. Windshield is still glass. Saved 84lbs on my 64.
Doug
