Thermoquad rod Qs #242741
03/04/09 10:54 AM
03/04/09 10:54 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Yesterday i checked the rods of my thermoquad strip kit and I found something odd.
If i get it right, the rods consist of three parts: the upper part which is of the same diameter, the middle part that narrows downwards and the lower part that is of the same diameter again.
when comparing the different rods of the strip kit side to side, the middle, narrowing part starts in different locations (lengths) of the rod (hope you understand what i mean).
Am i correct that it is the middle part that is responsible for part throttle mixture?
If so, then wouldnt the rod tree have to be adjusted to the individual rod, so that the beginning of the narrowing part sits in the right spot of the jet?
Am i correct or do i get something wrong?
just trying to understand how this stuff works.
Re: Theromquad rod Qs [Re: 440sat72] #242742
03/04/09 10:58 AM
03/04/09 10:58 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
If some of this doesn't get answered I will be in the shop later. I will check.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Theromquad rod Qs [Re: Rug_Trucker] #242743
03/04/09 01:27 PM
03/04/09 01:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The rods are not 3 differeint parts by default, like really depends of the rod model and specs. Diff rods to diff aplication and throttle response. There are rods with steps, rods with slopes, rods allmost straigth down
Check numbers stamped on Rods and will notice that probably you have two diff model of rods, so you are having diff response on each side of carb
Re: Theromquad rod Qs [Re: NachoRT74] #242744
03/04/09 01:34 PM
03/04/09 01:34 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Nope, what i meant is when you compare the different rods to each other.
Re: Theromquad rod Qs [Re: 440sat72] #242745
03/04/09 06:53 PM
03/04/09 06:53 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
i tried to make some pictures, unfortunately its pretty hard to make good pictures of such small parts. those are all different rods, compared next to each other. i hope you can see that the narrowing (middle) part is always in a different location.
Re: Theromquad rod Qs [Re: 440sat72] #242746
03/04/09 07:25 PM
03/04/09 07:25 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
VERY nice pics .... what type of camera do you have ?
Yes indeed ... there are a few rods like that but they are rare.
Re: Theromquad rod Qs [Re: 440sat72] #242747
03/04/09 07:43 PM
03/04/09 07:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yeh I know what you are talking BUT all those simply looks like non matching sets. Have you checked numbers stamped ?
all sets I have had are totally matched
Re: Theromquad rod Qs [Re: NachoRT74] #242748
03/04/09 08:14 PM
03/04/09 08:14 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
If I understand the OP correctly, yes they are different rods. He was asking about the location of the part throttle step varying between the different sets.
IE: a 1966 set of rods has the part throttle step further up from the WOT step than a different set like a 2159.
It's normal for the steps to vary, I have a few here that have a noticable difference. It allows tuning the carb for better responce and drivability.
I've always found that the tree needed to be tuned to the specific rod for correct operation when switching between numbers.
HTH
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: Theromquad rod Qs [Re: 78D150CLUB] #242749
03/05/09 09:32 AM
03/05/09 09:32 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I don't know t-quads, but if they work somewhat like the AFB's, where the "transition contour" between the wide part of the rod and the narrow part of the rod will determine when you get power enrichement and slightly vary the a/f curve as you go from high vaccuum part throttle to no vaccuum WOT.
2017 Grand Cherokee Overland
