Re: Theromquad rod Qs
[Re: Rug_Trucker]
#242743
03/04/09 01:27 PM
03/04/09 01:27 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
The rods are not 3 differeint parts by default, like really depends of the rod model and specs. Diff rods to diff aplication and throttle response. There are rods with steps, rods with slopes, rods allmost straigth down
Check numbers stamped on Rods and will notice that probably you have two diff model of rods, so you are having diff response on each side of carb
[Re: NachoRT74]
#242744
03/04/09 01:34 PM
03/04/09 01:34 PM
Posts: 1,603 germany
440sat72
germany
Nope, what i meant is when you compare the different rods to each other.
[Re: 440sat72]
#242747
03/04/09 07:43 PM
03/04/09 07:43 PM
NachoRT74
Valencia, España
Yeh I know what you are talking BUT all those simply looks like non matching sets. Have you checked numbers stamped ?
all sets I have had are totally matched
[Re: NachoRT74]
#242748
03/04/09 08:14 PM
03/04/09 08:14 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
If I understand the OP correctly, yes they are different rods. He was asking about the location of the part throttle step varying between the different sets.
IE: a 1966 set of rods has the part throttle step further up from the WOT step than a different set like a 2159.
It's normal for the steps to vary, I have a few here that have a noticable difference. It allows tuning the carb for better responce and drivability.
I've always found that the tree needed to be tuned to the specific rod for correct operation when switching between numbers.
HTH
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
[Re: 78D150CLUB]
#242749
03/05/09 09:32 AM
03/05/09 09:32 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I don't know t-quads, but if they work somewhat like the AFB's, where the "transition contour" between the wide part of the rod and the narrow part of the rod will determine when you get power enrichement and slightly vary the a/f curve as you go from high vaccuum part throttle to no vaccuum WOT.
