dust boot for lower ball joint
#2427387
01/01/18 08:52 PM
01/01/18 08:52 PM
Posts: 4,179 California
mickm
California
I mangled one taking the ball joints off, moog ball joints. I've been looking at http://www.suspension.com/universal-dust-boots.asp, and I can't find anything that matches. Does anyone know where to get these boots? I really don't want to buy a whole new ball joint just for a dust boot.
Re: dust boot for lower ball joint
[Re: mickm]
#2427397
01/01/18 09:09 PM
01/01/18 09:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ball joint PN?
https://www.speedwaymotors.com/Replacement-Screw-In-Ball-Joint-Dust-Boot-Mustang-II-K772-Application,100099.html
fits upper
[Re: solarguy]
#2427766
01/02/18 03:19 PM
01/02/18 03:19 PM
mickm
California
These aren't the correct dimensions from what I can see. I looked at the Heidts website, and they don't even list Chrysler in the product list.
[Re: mickm]
#2427778
01/02/18 03:44 PM
01/02/18 03:44 PM
Posts: 6,710 KY
65pacecar
KY
[Re: stumpy]
#2427796
01/02/18 04:08 PM
01/02/18 04:08 PM
mickm
California
Have you checked the Dorman help section of the local parts store. They do have a selection of replacement boots and you might find what you need. I will give that a try, thanks!
[Re: mickm]
#2427957
01/02/18 08:57 PM
01/02/18 08:57 PM
Posts: 15,851 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Something I've experienced with Moog dust boots the last few years is they don't last anymore. Within a year they are cracking and falling apart. And this is on cars that get 2,000 miles a year at most. Might want to consider urethane if you can find.
Facts are stubborn things.
[Re: 71birdJ68]
#2427971
01/02/18 09:27 PM
01/02/18 09:27 PM
mickm
California
Would an original fit? Frank Baldason has some of those. Yes, I just found them. Like Mancini, $100 for the kit. Probably wouldn't be bad to have spares around. Going to be $50 for a new ball joint, maybe I'll do this.
[Re: 68jim]
#2428144
01/03/18 03:02 AM
01/03/18 03:02 AM
mickm
California
Mickm,
I was rummaging through a cabinet in my garage today and came across a bag of dust boots. From what I can remember I think I pulled these off Moog parts and used the poly ones I bought as a kit. I have 4 ea of three different sizes. The small ones I'm pretty sure are tie rod ends. The middle size has "Mount Inboard" with an arrow and #7177 (openings 1.5" x 3/4" - just like the two top ones in the Roseville picture). The larger ones just have #7031 and have a small squared notch on the small opening (openings 1.75" x 3/4"). If you think one of these will work for you then I can drop them in the mail. Whoa! That's the one!!! I'll PM you!
[Re: mickm]
#2428151
01/03/18 03:17 AM
01/03/18 03:17 AM
RapidRobert
It's your lucky day Mick.
