dust boot for lower ball joint #2427387
01/01/18 08:52 PM
01/01/18 08:52 PM
California
mickm Offline OP
mickm  Offline OP
California
I mangled one taking the ball joints off, moog ball joints.
I've been looking at http://www.suspension.com/universal-dust-boots.asp, and I can't find anything that matches.
Does anyone know where to get these boots? I really don't want to buy a whole new ball joint just for a dust boot.
Re: dust boot for lower ball joint [Re: mickm] #2427397
01/01/18 09:09 PM
01/01/18 09:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ball joint PN?
https://www.speedwaymotors.com/Replacement-Screw-In-Ball-Joint-Dust-Boot-Mustang-II-K772-Application,100099.html
fits upper
Don't be the exception.
Re: dust boot for lower ball joint [Re: mickm] #2427479
01/01/18 11:48 PM
01/01/18 11:48 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Roseville Moparts has a boot seal pkg.listed for $39
http://www.rosevillemoparts.com/product_...roducts_id/7877
Re: dust boot for lower ball joint [Re: mickm] #2427485
01/02/18 12:04 AM
01/02/18 12:04 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Some act as merely umbrellas and do not retain the grease like the OEM boots that snap into a machined recess in the ball joint.
Make sure you are buying what you want.
Re: dust boot for lower ball joint [Re: DUSTER_340] #2427603
01/02/18 04:33 AM
01/02/18 04:33 AM
California
mickm Offline OP
mickm  Offline OP
California
Nice! I'll call them and see if this will fit the parts I have. will be nice to have spares as well!
Re: dust boot for lower ball joint [Re: mickm] #2427648
01/02/18 11:37 AM
01/02/18 11:37 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
Re: dust boot for lower ball joint [Re: DUSTER_340] #2427765
01/02/18 03:19 PM
01/02/18 03:19 PM
California
mickm Offline OP
mickm  Offline OP
California
unfortunately, they are back ordered and don't know when they will be in. Mancini apparently has a kit, $99. Still looking...
Re: dust boot for lower ball joint [Re: solarguy] #2427766
01/02/18 03:19 PM
01/02/18 03:19 PM
California
mickm Offline OP
mickm  Offline OP
California
Originally Posted By solarguy
These aren't the correct dimensions from what I can see. I looked at the Heidts website, and they don't even list Chrysler in the product list.
Re: dust boot for lower ball joint [Re: mickm] #2427778
01/02/18 03:44 PM
01/02/18 03:44 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Re: dust boot for lower ball joint [Re: mickm] #2427781
01/02/18 03:46 PM
01/02/18 03:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the Dorman help section of the local parts store. They do have a selection of replacement boots and you might find what you need.
Re: dust boot for lower ball joint [Re: stumpy] #2427796
01/02/18 04:08 PM
01/02/18 04:08 PM
California
mickm Offline OP
mickm  Offline OP
California
I will give that a try, thanks!
Re: dust boot for lower ball joint [Re: mickm] #2427867
01/02/18 06:12 PM
01/02/18 06:12 PM
California
mickm Offline OP
mickm  Offline OP
California
Wow, this is getting to be a bummer, and taking a lot of time.
A well stocked local store had nothing. I tried looking up Moog itself, hoping to talk with someone and see if I can get a boot, but I can't even find them on the web, only independent dealers selling moog.
I'm getting close to saying f*ck it, and just buying another.
Re: dust boot for lower ball joint [Re: mickm] #2427883
01/02/18 06:33 PM
01/02/18 06:33 PM
California
mickm Offline OP
mickm  Offline OP
California
Well, I did get hold of someone at moog. He is sending me a dust boot, but it isn't the exact one that the ball joint comes with, so it's a shot in the dark. If it works, I'm done, but otherwise it's a new ball joint!
Re: dust boot for lower ball joint [Re: mickm] #2427940
01/02/18 08:10 PM
01/02/18 08:10 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Would an original fit? Frank Baldason has some of those.
Re: dust boot for lower ball joint [Re: mickm] #2427957
01/02/18 08:57 PM
01/02/18 08:57 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Something I've experienced with Moog dust boots the last few years is they don't last anymore. Within a year they are cracking and falling apart. And this is on cars that get 2,000 miles a year at most. Might want to consider urethane if you can find.
Facts are stubborn things.
Re: dust boot for lower ball joint [Re: 71birdJ68] #2427971
01/02/18 09:27 PM
01/02/18 09:27 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, I just found them. Like Mancini, $100 for the kit. Probably wouldn't be bad to have spares around. Going to be $50 for a new ball joint, maybe I'll do this.
Re: dust boot for lower ball joint [Re: mickm] #2428030
01/02/18 10:53 PM
01/02/18 10:53 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Mickm,
I was rummaging through a cabinet in my garage today and came across a bag of dust boots. From what I can remember I think I pulled these off Moog parts and used the poly ones I bought as a kit. I have 4 ea of three different sizes. The small ones I'm pretty sure are tie rod ends. The middle size has "Mount Inboard" with an arrow and #7177 (openings 1.5" x 3/4" - just like the two top ones in the Roseville picture). The larger ones just have #7031 and have a small squared notch on the small opening (openings 1.75" x 3/4"). If you think one of these will work for you then I can drop them in the mail.
Re: dust boot for lower ball joint [Re: 68jim] #2428050
01/02/18 11:43 PM
01/02/18 11:43 PM
IN
ahy Offline
ahy  Offline
IN
Good luck! Often a replacement ball joint will have the generic umbrella type also. I use that, or a generic umbrella cover from the help section or a poly boot and grease each oil change.
If you find something better please post it.
Re: dust boot for lower ball joint [Re: 68jim] #2428144
01/03/18 03:02 AM
01/03/18 03:02 AM
California
mickm Offline OP
mickm  Offline OP
California
Originally Posted By 68jim
Mickm,
Whoa! That's the one!!! I'll PM you!
Re: dust boot for lower ball joint [Re: mickm] #2428151
01/03/18 03:17 AM
01/03/18 03:17 AM
It's your lucky day Mick.
