Mopar BB Intake manifold swap? torque specs? #242698
03/04/09 04:59 AM
03/04/09 04:59 AM
Davis, California, USA
MrBelvedere2 Offline OP
I am about to swap my 2 barrel cast iron intake on my 361 for an Edelbrock DP4B and 600 cfm carb i scored. I got my gasket kit from napa and there is only a 1 peice valley tray? do you use sealer with this or do you just torque it down and it forms a crush seal? I have never done an intake swap on a BB before so excuse my ignorance. I also would like to know the pattern to tighten the bolts and torque spec's for the intake. so if you would be so kind to go over the procedure for me that would be awesome..thank you!
1965 Plymouth Belvedere II hardtop
Re: Mopar BB Intake manifold swap? torque specs? [Re: MrBelvedere2] #242699
03/04/09 05:09 AM
03/04/09 05:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
it seems that there's about 900 different ways to do this. my engine gasket kit came with 4 gaskets, and the book calls for 1 between the head and the valley tray, and another between the valley tray and the intake. to me, this seemed excessive, and what I did was used RTV to seal the valley pan to the head, and a paper gasket to seal the intake to the pan, with RTV to hold it in place on the intake until I got the bolts in and lined up.
...or was that paper between head and pan, and RTV between intake and pan?
crap. now I can't remember!
just make sure it's sealed well and has no leaks!
**Photobucket sucks**
Re: Mopar BB Intake manifold swap? torque specs? [Re: MrBelvedere2] #242700
03/04/09 10:38 AM
03/04/09 10:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I always use just the tins.No paper.Only place for RTV is at the very corners of the heads and where the hold down are.Tighten to 25 Ft Lbs.I just start in the middle and switch from one side to the other going to a frt then a rear.Just snug them down then tighten all the way.Been doing it for over 40 years and never a leak.The papers IMHO are a total waste and some dummys answer to make simple complicated.Ma didnt use them and I dont.Oh I always use antisieze on the bolts.Rocky
Chrysler Firepower
Re: Mopar BB Intake manifold swap? torque specs? [Re: therocks] #242701
03/04/09 11:04 AM
03/04/09 11:04 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Mopar BB Intake manifold swap? torque specs? [Re: therocks] #242702
03/04/09 11:12 AM
03/04/09 11:12 AM
My fav is #2 permatex(the thick brown goo in the toothpaste tube), it stays pliable, a light thin EVEN coat around the intake ports and the water ports on BOTH sides of the tin gasket & no paper gaskets which are available seperately for that tin gasket. 77 shop manual shows 45 ft lbs & I couldn't find the pattern anywhere even in the Senatore BB book. RTV will work just need the specific "color" that will resist gasoline and coolant on the intake ports & the coolant ports.
Re: Mopar BB Intake manifold swap? torque specs? [Re: RapidRobert] #242703
03/04/09 11:37 AM
03/04/09 11:37 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
there's no coolant ports on a bigblock intake.
Re: Mopar BB Intake manifold swap? torque specs? [Re: dirtybee] #242704
03/04/09 11:41 AM
03/04/09 11:41 AM
yes! I stand corrected. I've been on SB's for quite awhile now
Re: Mopar BB Intake manifold swap? torque specs? [Re: RapidRobert] #242705
03/04/09 05:04 PM
03/04/09 05:04 PM
IA
landon1 Offline
landon1  Offline
IA
Sequence is TOP ROW: 7, 3, 1, 5
BOT ROW: 8, 4, 2, 6
'71 Satellite Sebring 440
Re: Mopar BB Intake manifold swap? torque specs? [Re: landon1] #242706
03/04/09 09:23 PM
03/04/09 09:23 PM
BOT ROW: 8, 4, 2, 6
thank you Landon1. I wrote it on the back page of Senatores book so I will know where it's at when I need it. EDIT I was thinking that the torque spec is 35 now that I think about it as 3/8" coarse thread(16 tpi)bolts are common for us & alot of them that size are listed at 35 ft lbs but yours & my 77 shop manual says 45 and my 1967 "glenns" says that BB intake manifold torque is 50 lbs which for sure is too much.
Re: Mopar BB Intake manifold swap? torque specs? [Re: RapidRobert] #242707
03/05/09 05:57 PM
03/05/09 05:57 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Now what about with an aluminum intake? I have a Weiand, and bought a FelPro valley pan which came with the (4) gaskets mentioned above. I use the Permatex goop for everything, I love it, is that enough with just the valley pan?
Re: Mopar BB Intake manifold swap? torque specs? [Re: 4BBodies] #242708
03/05/09 08:17 PM
03/05/09 08:17 PM
the torque spec is more about the amt necc to stretch the bolt(not too much not to little) to get the right amt of tension. I'd toss the paper gaskets, use your favorite goop(if RTV which I dont like for this) use a gasoline resistant color & 35 lbs in his pattern & you're good.
Re: Mopar BB Intake manifold swap? torque specs? [Re: RapidRobert] #242709
03/06/09 08:07 AM
03/06/09 08:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
All I run is aluminum intakes.Torque to 25 is more than enough.The spec in manual is for iron intake.Ive never run papers and no leaks in 40 plus years.Same with sealer.Its not needed just at the 4 corners and a little under where the hold downs go.If you need sealer something is warped.Ive even reused the tins.Back in the day they were like 30 bucks or more and that was in 1960s money.Rocky
Chrysler Firepower
