70-71- E-body dash wiring routing #2425142
12/28/17 11:31 PM
12/28/17 11:31 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
lookin to see if anyone has a pic of the back of a dash, wiring routing for the bulk head wiring. thanks
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2425225
12/29/17 02:59 AM
12/29/17 02:59 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Maybe a more specific request?, rallye dash?, gauge wiring? or just general lay out?...as I have quite a few diagrams, pics, factory prints, etc...
Mike
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425226
12/29/17 03:06 AM
12/29/17 03:06 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just an example
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425232
12/29/17 03:32 AM
12/29/17 03:32 AM
That is awesome Dayclona, Ralley dash , general lay out, when I took this apart it was horrible, just lookin to make it easier on myself..
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2425514
12/29/17 08:13 PM
12/29/17 08:13 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a moparts pic that was from the old days...Passed around quite a bit..
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2425878
12/30/17 03:59 PM
12/30/17 03:59 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'll give you what I have as far as general layout on the dash/rallye cluster, wiper switch/column/etc, I could supply some wiring diagrams from the FSM if those are needed?
keep in mind some pics are 70 or 71, or 70/71 applications, some are Cuda or Challenger specific, FACTORY prints with the lower box designations B/BH/BS/BP designation are Cuda only, Challenger only are J/JH specific, F series is 70, G series is 71 specific when trying to identify your application
If you need a blow up of a specific area that you can't see, let me know
hope it helps
Mike
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425881
12/30/17 04:00 PM
12/30/17 04:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425885
12/30/17 04:02 PM
12/30/17 04:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425886
12/30/17 04:03 PM
12/30/17 04:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425888
12/30/17 04:06 PM
12/30/17 04:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425890
12/30/17 04:07 PM
12/30/17 04:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
3spd stuff
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425893
12/30/17 04:08 PM
12/30/17 04:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2425896
12/30/17 04:12 PM
12/30/17 04:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2426406
12/31/17 04:25 PM
12/31/17 04:25 PM
Thank you both, should be at the wiring soon and those pics will work, thanks again up
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2426736
12/31/17 10:13 PM
12/31/17 10:13 PM
Ok , I have other questions, does anyone have pics of the interier, where the shaker switch and the road lamp switches are mounted, I'm trying to get this correct as the car was horrible thanks
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2426754
12/31/17 10:28 PM
12/31/17 10:28 PM
Harrisburg, Pa.
Harrisburg, Pa.
Here's the dash frame pic...
Re: 70-71- E-body dash wiring routing [Re: screamindriver] #2426775
12/31/17 10:41 PM
12/31/17 10:41 PM
thank you , anything on the road lamp switch
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2426904
01/01/18 02:19 AM
01/01/18 02:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
For now...
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2426910
01/01/18 02:26 AM
01/01/18 02:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...here's more rallye dash also
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2426917
01/01/18 02:41 AM
01/01/18 02:41 AM
I would just like a pic of the switch in the vehicle, for the road lamp, thanks
