EFI IAT sensor location #2425802
12/30/17 02:19 PM
12/30/17 02:19 PM
Indiana
EV2DEMON Offline OP
The Camaro Kid
EV2DEMON  Offline OP
The Camaro Kid
Indiana
For those with EFI using a 4150 style throttle body on a single plane intake, where are you putting your IAT sensor? Looks like my best option may be to drill and tap a carb spacer and put it there. Any other ideas?
Re: EFI IAT sensor location [Re: EV2DEMON] #2425828
12/30/17 02:51 PM
12/30/17 02:51 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had a victor manifold that I drilled and tapped for a sensor just below the carb base, I used that when I was using my megasquirt system to control 8 coils but I was still using a carb. When I finished the fuel side I used a Holley 4150 throttle body that has the sensor at the inlet of the throttle body.
68 Barracuda Formula S 340
Re: EFI IAT sensor location [Re: Bad340fish] #2425855
12/30/17 03:22 PM
12/30/17 03:22 PM
Indiana
EV2DEMON Offline OP
The Camaro Kid
EV2DEMON  Offline OP
The Camaro Kid
Indiana
So the Holley TB has an integrated IAT sensor? That certainly simplifies things. Thanks!
Re: EFI IAT sensor location [Re: EV2DEMON] #2425904
12/30/17 04:24 PM
12/30/17 04:24 PM
AndyF Offline
AndyF  Offline
Yes, but only if you buy the correct throttle body. They sell a few different ones and it is a little hard to figure out from the description.
The throttle body that I have has TPS, IAC and MAT sensors built in and it has multiple vacuum ports for PCV, MAP, vacuum gauge and ported vacuum for a distributor.
Re: EFI IAT sensor location [Re: EV2DEMON] #2425963
12/30/17 06:01 PM
12/30/17 06:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have the same throttle body as Andy does. I will soon be running two of them on a T-ram, I will have some spare sensors for the road lol
Re: EFI IAT sensor location [Re: Bad340fish] #2425994
12/30/17 07:14 PM
12/30/17 07:14 PM
Indiana
EV2DEMON Offline OP
The Camaro Kid
EV2DEMON  Offline OP
The Camaro Kid
Indiana
Ok, so I just ordered a Holley 112-588 tb. Looks like it comes with tps & IAT sensors. Thanks all.
Re: EFI IAT sensor location [Re: EV2DEMON] #2426000
12/30/17 07:24 PM
12/30/17 07:24 PM
AndyF Offline
AndyF  Offline
112-588 is the throttle body in my picture so that should work for you. You'll still need a MAP sensor but that is fairly easy to hook up since the throttle body has vacuum ports on it. Just run a vacuum line from the throttle body to a MAP sensor that you mount on the firewall. The cheap GM MAP sensors can be mounted with a couple of screws and they have a vacuum port nipple on them. The Holley wiring harness will plug right in.
Re: EFI IAT sensor location [Re: EV2DEMON] #2426958
01/01/18 06:44 AM
01/01/18 06:44 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
That’s a nice throttle cable bracket
Re: EFI IAT sensor location [Re: crash520] #2427094
01/01/18 02:41 PM
01/01/18 02:41 PM
AndyF Offline
AndyF  Offline
Thanks. Part of my new EFI lineup of parts for 2018. I should have that throttle bracket on the website shortly. I have some of them in stock now ready to sell. I made them out of stainless steel so they should look nice for a long time.
Re: EFI IAT sensor location [Re: AndyF] #2428039
01/02/18 11:15 PM
01/02/18 11:15 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Will they work on a FAST TBI unit?, I’m travelling to the US end of this month, would be nice to be able to pick one up
Re: EFI IAT sensor location [Re: EV2DEMON] #2428147
01/03/18 03:10 AM
01/03/18 03:10 AM
AndyF Offline
AndyF  Offline
Should work on anything with a standard 4150 bolt pattern. Part number is AR134EFI. Rich at FAST Man EFI should be able to get one for you. Mancini and Hughes haven't really started to stock the EFI parts yet.
Re: EFI IAT sensor location [Re: EV2DEMON] #2428183
01/03/18 08:28 AM
01/03/18 08:28 AM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I’ll be heading to Olympia WA first week of Feb, could I not just buy one from your website and have it shipped to my mate up there for my collection Andy?
