Re: 315 Square setup E-body `Cuda
[Re: UCUDANT]
#2422211
12/22/17 04:59 AM
12/22/17 04:59 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Sorry, most of my pictures are held hostage by Photobucket so blame them if you can't see. I am going to have to retract my previous statement of possibly fitting 335's in the rear. My setup is actually rubbing in the upper wheel wells upon further inspection. It must be rubbing due to the body roll while cornering. The rubbing is just slight on the tire but, is no way ideal. 315's are definitely attainable, no doubt. With leaf springs, one will have to relocate them inboard 1.5" using Dr. Diff's kit and roll the rear fenders. Once those two things are done its just a matter of finding the correct offset wheels. I am having more issues fitting them in the rear than in the front haha!
[Re: RylisPro]
#2427570
01/02/18 02:40 AM
01/02/18 02:40 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Rylis -- nice work!! Mine are flushed/pulled... still appears stock...
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: RylisPro]
#2439146
01/22/18 06:59 PM
01/22/18 06:59 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I finished the driver side and took before and after pics: Before After Added about 5/8" additional clearance My advice when rolling the fenders is to take your time and check your work. I got a bit too greedy and the fender concaved in a bit. I had to pop it out from the inside and everything looks great now.
[Re: mcmopar1]
#2568518
10/23/18 07:12 PM
10/23/18 07:12 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Because that would mean more time that the car is down and getting worked on again which means less time on the road course Thanks!
[Re: TC@HP2]
#2569056
10/24/18 07:26 PM
10/24/18 07:26 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Moving the leaf springs inboard reduces the wheel rate about 10# per inch, so similar to running a lighter spring rate in the stock position.
Now, whether or not the butt dyno can feel a 30# rate change per side is highly subjective. Only in roll, to be clear?
[Re: jcc]
#2569060
10/24/18 07:32 PM
10/24/18 07:32 PM
jcc
Bitopia
I don't see much reference to the fronts, any real issues there with fitment? Looks great . Function over form
[Re: jcc]
#2569328
10/25/18 12:46 PM
10/25/18 12:46 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Now, whether or not the butt dyno can feel a 30# rate change per side is highly subjective. Only in roll, to be clear? This would be in both ride and roll rate because the mounting location is altered, impacting the geometric formula.
[Re: TC@HP2]
#2569361
10/25/18 01:59 PM
10/25/18 01:59 PM
jcc
Bitopia
You are a member over many years I seldom ever disagree with, but this is one.
Leaf spring location relative to the tire contact patch does not change spring rate in ride, as there is not motion ratio other the 1:1.
[Re: TC@HP2]
#2569362
10/25/18 02:00 PM
10/25/18 02:00 PM
jcc
Bitopia
Now, whether or not the butt dyno can feel a 30# rate change per side is highly subjective. Only in roll, to be clear? This would be in both ride and roll rate because the mounting location is altered, impacting the geometric formula. You are a member over many years I seldom ever disagree with, but this is one. Leaf spring location with a solid axle relative to the tire contact patch does not change spring rate in ride, as there is no motion ratio other the 1:1.
[Re: Consulier]
#2569467
10/25/18 05:45 PM
10/25/18 05:45 PM
jcc
Bitopia
Summit $781/ea Brand:Pirelli Manufacturer's Part Number:2307500 Part Type:Tires Product Line:Pirelli P Zero Corsa System Tires Summit Racing Part Number:PIR-2307500 Wheel Diameter: 19 in. Tire Size: 355/30-19 Sidewall Style: Blackwall Tire Construction: Radial Tire Diameter: 27.40 in. Section Width: 14.00 in. Minimum Recommended Wheel Width: 12.00 in. Maximum Recommended Wheel Width: 13.00 in. Directional: No Speed Rating: Y Load Index: 99 Asymmetrical Tread Pattern: No UTQG Tread Wear Rating: 60 Traction Rating: AA Temperature Rating: A Tread Depth: 8/32 in. DOT-Approved: Yes Run-Flat Technology: No Tube Required: No Max Load Single (lbs): 1,709
