Page 4 of 5 1 2 3 4 5
Re: 315 Square setup E-body `Cuda [Re: UCUDANT] #2422211
12/22/17 04:59 AM
12/22/17 04:59 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Sorry, most of my pictures are held hostage by Photobucket so blame them if you can't see.
I am going to have to retract my previous statement of possibly fitting 335's in the rear. My setup is actually rubbing in the upper wheel wells upon further inspection. It must be rubbing due to the body roll while cornering. The rubbing is just slight on the tire but, is no way ideal.
315's are definitely attainable, no doubt. With leaf springs, one will have to relocate them inboard 1.5" using Dr. Diff's kit and roll the rear fenders. Once those two things are done its just a matter of finding the correct offset wheels.
I am having more issues fitting them in the rear than in the front haha!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2422247
12/22/17 10:57 AM
12/22/17 10:57 AM
Colorado
MoparCar Offline
MoparCar  Offline
Colorado
Unfortunately Dr. Diff I believe quit making the 1.5" offset kits according to correspondence about a half a year ago.
Wes
Re: 315 Square setup E-body `Cuda [Re: MoparCar] #2422395
12/22/17 06:24 PM
12/22/17 06:24 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I just called Cass and the reasons he stopped making them were because too many people complained that they interfere with a full length exhaust and that they will leave two small dimples on the `Cuda rear valance.
That's too bad, it was a nice product. If enough people ask him nicely though...
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2425662
12/30/17 04:40 AM
12/30/17 04:40 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Here is the damage from the 315 rubbing in the rear, minimal but not at all ideal.
Some rear fender rolling progress
Eastwood says their roller does not work with thick double wall rear fender sheet metal of most muscle cars but that is all baloney, it works fine, just need a big F'ing hammer also.
Before shot from a while back
This mod is not too bad since I don't have nice paint. Believe me I wasn't gentle on these fenders at all as they are not that easy to fold up. A few whacks of a big hammer does the trick to bend the metal up, then I used the roller fender to get the shape I want. I took my time as didn't want the rear fender to concave in permanently as it would flex when rolling at a certain spot.
Not too bad as I have never rolled fenders before. I still have to do the driver side and I think it adds about an extra inch of clearance. I'll post up actual measurements of before and after at a later time.
My spine is still killing me due to being crouched down under the fender all day haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2425727
12/30/17 12:29 PM
12/30/17 12:29 PM
moparx Offline
moparx  Offline
just wait until a year or 40 passes, then come back and report how your aches feel ! biggrin only a tad of experience talking here.......
beer
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2427570
01/02/18 02:40 AM
01/02/18 02:40 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Rylis -- nice work!! Mine are flushed/pulled... still appears stock...
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2439146
01/22/18 06:59 PM
01/22/18 06:59 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I finished the driver side and took before and after pics:
Before
After
Added about 5/8" additional clearance
My advice when rolling the fenders is to take your time and check your work. I got a bit too greedy and the fender concaved in a bit. I had to pop it out from the inside and everything looks great now.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2567697
10/22/18 09:49 AM
10/22/18 09:49 AM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
Why not use a mini tub and relocate the springs into the frame rails? US Cartool has a “kit” for it.
Re: 315 Square setup E-body `Cuda [Re: mcmopar1] #2568518
10/23/18 07:12 PM
10/23/18 07:12 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Because that would mean more time that the car is down and getting worked on again
which means less time on the road course
Thanks!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2568684
10/24/18 12:50 AM
10/24/18 12:50 AM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
Right, I get it! Would it adversely affect handling?
Re: 315 Square setup E-body `Cuda [Re: mcmopar1] #2568691
10/24/18 01:12 AM
10/24/18 01:12 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Yes it would definitely would affect handling if one were to add mini tubs. If we did that we would also fit the widest tires possible maybe a 345 or even wider? The problem is that the fronts will only be 315's wide and it would cause severe understeer at the track.
Actually it might be a benefit because currently we oversteer too much haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2568728
10/24/18 06:37 AM
10/24/18 06:37 AM
raleigh, NC
mcmopar1 Offline
mcmopar1  Offline
raleigh, NC
345’s would look awesome.....but moving the springs in 3” or so each side would have no affect on the handling?
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2568938
10/24/18 03:41 PM
10/24/18 03:41 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Moving the leaf springs inboard reduces the wheel rate about 10# per inch, so similar to running a lighter spring rate in the stock position.
Now, whether or not the butt dyno can feel a 30# rate change per side is highly subjective.
Re: 315 Square setup E-body `Cuda [Re: TC@HP2] #2569056
10/24/18 07:26 PM
10/24/18 07:26 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Only in roll, to be clear?
Re: 315 Square setup E-body `Cuda [Re: jcc] #2569060
10/24/18 07:32 PM
10/24/18 07:32 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I don't see much reference to the fronts, any real issues there with fitment?
Looks great .
Function over form up
Re: 315 Square setup E-body `Cuda [Re: jcc] #2569328
10/25/18 12:46 PM
10/25/18 12:46 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
This would be in both ride and roll rate because the mounting location is altered, impacting the geometric formula.
Re: 315 Square setup E-body `Cuda [Re: TC@HP2] #2569361
10/25/18 01:59 PM
10/25/18 01:59 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
You are a member over many years I seldom ever disagree with, but this is one.
Leaf spring location relative to the tire contact patch does not change spring rate in ride, as there is not motion ratio other the 1:1.
Re: 315 Square setup E-body `Cuda [Re: TC@HP2] #2569362
10/25/18 02:00 PM
10/25/18 02:00 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
You are a member over many years I seldom ever disagree with, but this is one. eek
Leaf spring location with a solid axle relative to the tire contact patch does not change spring rate in ride, as there is no motion ratio other the 1:1.
Re: 315 Square setup E-body `Cuda [Re: RylisPro] #2569445
10/25/18 04:36 PM
10/25/18 04:36 PM
USA
Consulier Offline
Consulier  Offline
USA
I have a pile of leftover 355's from this season if you want any for fitment testing.
355 square is where you want to be... up
Re: 315 Square setup E-body `Cuda [Re: Consulier] #2569467
10/25/18 05:45 PM
10/25/18 05:45 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Summit $781/ea eek
Brand:Pirelli
Manufacturer's Part Number:2307500
Part Type:Tires
Product Line:Pirelli P Zero Corsa System Tires
Summit Racing Part Number:PIR-2307500
Wheel Diameter: 19 in.
Tire Size: 355/30-19
Sidewall Style: Blackwall
Tire Construction: Radial
Tire Diameter: 27.40 in.
Section Width: 14.00 in.
Minimum Recommended Wheel Width: 12.00 in.
Maximum Recommended Wheel Width: 13.00 in.
Directional: No
Speed Rating: Y
Load Index: 99
Asymmetrical Tread Pattern: No
UTQG Tread Wear Rating: 60
Traction Rating: AA
Temperature Rating: A
Tread Depth: 8/32 in.
DOT-Approved: Yes
Run-Flat Technology: No
Tube Required: No
Max Load Single (lbs): 1,709
