Need some criticism on a build #2425342
12/29/17 01:50 PM
12/29/17 01:50 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I have a 440 bored out .30.
A 505 stroker with a 4.250 crankshaft
6700 rods
forged flat top pistons
internal balanced
Performer RPM 440 88cc Cylinder Heads
Dual plane PERFORMER RPM 440 intake
Holley 850 carb
XE295HL Comp cam
10" Converter 3000-3400 Stall
8.75 rear with 3.55 gears
What would you do different to this build. It being a stroker motor doesnt feel like i'm getting the most out of it.
Re: Need some criticism on a build [Re: Shatar4] #2425348
12/29/17 01:57 PM
12/29/17 01:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Have you run it yet?
If so, what does it not do that you'd like it to do better?
With mild gearing and stall, there isn't a lot you can do and not lose some of the street friendly nature of a build like that.
The one thing I wouldn't have done is used the open chamber heads with flat top pistons.
Re: Need some criticism on a build [Re: Shatar4] #2425526
12/29/17 08:44 PM
12/29/17 08:44 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Nothing like trying to inhale thru a tiny straw with a dual plane intake and small carb...
Even with a mild cam, I would be running a 950 carb on an open plenum intake. That will double the air flow the engine gets right there.
Shorten the timing curve to get as much initial timing as possible with a quick advance.
Re: Need some criticism on a build [Re: Shatar4] #2425541
12/29/17 09:31 PM
12/29/17 09:31 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Whose rotating kit is it? Know what the compression is with those 88cc heads?
I just built a 400 based 512 with Edelbrock 84cc heads. Compression came out to 10.5 and used an Edelbrock Torquer 383 intake (single plane). If I'm missing any low end torque because of it I sure don't miss it.
Re: Need some criticism on a build [Re: Shatar4] #2425545
12/29/17 10:01 PM
12/29/17 10:01 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Big engine small head. Should have built a 440 with those heads and intake.
Re: Need some criticism on a build [Re: Shatar4] #2425553
12/29/17 10:18 PM
12/29/17 10:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Biggest mistake was the Open chamber heads with the flat top pistons, losing all quench benefits. Could of had the same comp with .060 gaskets and quench. Other then that maybe more stall, but Don't really know your overall intentions for the combo. I'm thinking strong torque street build with some occasional track time.
Re: Need some criticism on a build [Re: Shatar4] #2425557
12/29/17 10:47 PM
12/29/17 10:47 PM
jersey
Spaceman Spiff Offline
jersey
i had an RPM intake and 850 carb on my 526.
switched to an M1, and a 1000cfm quick fuel carb. car was good before for a 4,600lb tank, but after the swap, it's an animal.
change the intake and carb.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Need some criticism on a build [Re: Spaceman Spiff] #2425563
12/29/17 11:17 PM
12/29/17 11:17 PM
Our mild, street, all cast iron, 526RB in a heavy steel B-body went 6.94 this year in the 1/8th....On pump gas!
Re: Need some criticism on a build [Re: Shatar4] #2425575
12/30/17 12:07 AM
12/30/17 12:07 AM
AndyF Offline
AndyF  Offline
I don't see anything wrong with that combo unless you're building a race car. Should be a nice strong street engine. If you want to add some power then step up to a hyd roller cam with more lift in the next upgrade.
If it is a driver that sees a lot of miles I'd ditch the double pumper and put on a Holley Sniper system. It will run a better and the engine will last longer.
Re: Need some criticism on a build [Re: Shatar4] #2425585
12/30/17 12:52 AM
12/30/17 12:52 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Its okay imo. If it were mine I'd go closed chamber heads with zero deck piston with the right piston dish for about 10.5 CR.
I'd maybe consider a little less cam, or maybe more carb/intake. But this is picking the fly sh** from the pepper, and easy changes once you get it running to get it to match your objectives.
Re: Need some criticism on a build [Re: Shatar4] #2425633
12/30/17 03:39 AM
12/30/17 03:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My question is what everyone else is asking and thats why the open chamber heads ? Do you know the real comp ratio ? And you wont have good quench either. I dont know the specs of that cam off the top of my head but the rest of the combo is not to far from mine. But I use EZ heads and have 10.6 comp with quench and mine runs fine on 92 pump. I use more gear with 4.30's and a 30" tall tire and I may gear down as I dont think it needs that much to run the same et. I run a 9.5 Dynamic street/strip type converter that flashes about 4200 and works good at the track but drives around like a normal converter. I also run a dual plane intake but I use the Indy dual plane which has pretty good size ports and runners and I run a 850 Holley DP. I agree with others that mine may go faster with more carb but it dont run to bad with the 850 and has great street manners with it. But you need to know what your real comp is to start with ? Ron
Re: Need some criticism on a build [Re: Dragula] #2425651
12/30/17 04:17 AM
12/30/17 04:17 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Right after I'm verifying 0 deck and milling the heads to 79 cc.
Re: Need some criticism on a build [Re: cudadoug] #2425749
12/30/17 01:01 PM
12/30/17 01:01 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
If it doesn't come up to your expectaions the first thing I would check is your ignition curve, Stroker BBM's with street compression ratios tend to like a fair amount of initial timing combined with a limited/shortened centrifugal advance that's all in by around 2600-2800, timing can make a huge difference in performance. Several Times I've seen guys who never really built strokers before get them running with 10-12 degrees and they start and idle "fine" but the power and torque just isn't there when they drive them....Fix the timing and "BAM"! instant stroker happiness.
Back before we had all the closed chamber head choices Diamond and I think KB used to sell pistons with a "qunch step" so technically is had a flat dome that would take up a good portion of the open chamber. I built a really nice running 508" RB with some well ported Stage V's that ran really strong with a mild Hydraulic roller. That beast is still out there somewhere, I need to check with Paul PHJ426 to see where it's at.
Was there any work at all done to the heads? With strokers picking up the mid lift flows (particularly the .250-.450 numbers) really helps the torque and HP curve above the torque peak. As I remember the OOTB edelbrocks aren't really "killer" at .400 lift but they are easy to improve with skilled bowl/runner work like you can get from Dwayne Porter. just getting from 260 cfm to 280 at ~.450 lift will really wake up a strokers power curve. And combined with a better/more consistent (than delivered OOTB) valve job helps the snap and response and can act like a bit more agressive cam profile with no downside.
The pistons are obviously not going to help you (just something for readers to keep in mind) but possibly swapping your heads for a closed chamber like these new TF 240's and either port the RPM or swap it for a Holley Street Dominator with a little port and mainly plenum work would likely help out immensely. A custom calibrated 950HP or 1000HP 4150 base carb would help the breathing up top, as said with a dual plane each bank is effectivly limited to seeing only 1/2 the carb so the combination of a small runner/port with a small-ish carb puts restrictions in series which makes matters worse.
See where your curve is first, try running something like 16-20 degrees initial and limiting total (initial plus centrifugal) advance to 34-36, I'll bet that will make a difference. On paper your motor should run strong.
WIZE
In Car:
Re: Need some criticism on a build [Re: Streetwize] #2426099
12/30/17 11:09 PM
12/30/17 11:09 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
iagree
I was one of those guys. All I had built up to that point was stock stroke small blocks. I tried what I knew and 14 degrees initial. Ran like crap. Settled at 24 degrees initial with a total of 34 all in at around 3200. Absolutely fries the 285 Nittos. I could probably bring it in sooner still. More tuning for Spring.
Re: Need some criticism on a build [Re: Shatar4] #2426224
12/31/17 08:21 AM
12/31/17 08:21 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
After reading all the responses I guess the first thing is to get rid of the 88cc heads and get some closed chambered heads.
I always thought that this motor never lived up to the expectations I had for a Stroker Motor and something was missing.
So a recap is:
Change the heads
Change the intake to a single plane
Change carb to a 950?
Thanks for all the responses. I really do appreciate it
Re: Need some criticism on a build [Re: Shatar4] #2426228
12/31/17 10:15 AM
12/31/17 10:15 AM
So a recap is:
Change the heads
Single biggest bang for the buck is the intake....Swap it, and jet the carb up and shorten your timing curve. A small carb really only hurts the top end. With the right squirters and jets, you can gain a bunch on the low end with what you have. An 850 will not have the size squirters or enough jet in it for that engine. We run #45's front and rear in all our stroker carbs once we get enough initial timing in them. #37 is the smallest we have run, and they are always lean that way.
Heck, we have been switching them lately to 50cc accel pumps front and rear just to get enough fuel shot in these engines. THATS when we really see the 60fts come down...But don't tell Thumper...
Shortening the timing curve varies depending on distributor, but the more initial timing, say idle around 22* and total in by 2500, the more fuel it will take in, and the snappier it will be. You will have to tinker to get this. We have used MSD and Firecore distributors, and both work well. Also, we have found ours like a lot of total timing. Not sure why, but my big 512RB had to have 38* total or it was .15 slower...
A 505 should be a beast! Our 512's are really nasty for a simple RB stroker. They idle well, and just fry the daylights out of a set of tires or slicks, let alone what they run on the track.
You gots to learn what it wants....read the plugs, put a wide band on it, try jet changes, tinker with timing....
Re: Need some criticism on a build [Re: Dragula] #2426247
12/31/17 11:37 AM
12/31/17 11:37 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
So your saying the intake should be changed and leave the heads on it?
Re: Need some criticism on a build [Re: Shatar4] #2426252
12/31/17 12:02 PM
12/31/17 12:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Guess that I missed that it is already running.
Without some track data it is hard to distinguish between something wrong verses adjusting the combo. What is you cylinder pressure, and fuel pressure at WOT?
Re: Need some criticism on a build [Re: Shatar4] #2426260
12/31/17 12:23 PM
12/31/17 12:23 PM
Idaho
LaRoy Engines Offline
Idaho
Okay, so we are recommending going to a closed chamber head of 78-84 cc's and potentially bumping the compression to somewhere's around 11.4-12.1?
Re: Need some criticism on a build [Re: LaRoy Engines] #2426276
12/31/17 01:13 PM
12/31/17 01:13 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I did the math before suggesting going to flat tops. going from a 88 cc head to a 84 cc head with a .060 gasket nets the same exact comp of around 11.1
He asked for criticism on the build, that's one of the things I would of done differently. I also asked what his main intentions for the build would be and didn't get a answer. the combo as it should be torque running sob.
