Page 2 of 2 < 1 2
#2426923 - 01/01/18 12:03 AM Re: 70-71- E-body dash wiring routing [Re: 70Challengerse]
DAYCLONA Offline
Loc: Mass
Originally Posted By 70Challengerse
I would just like a pic of the switch in the vehicle, for the road lamp, thanks
I'll just post pics of 70/71 RALLEY dash switches only
Mike
#2426924 - 01/01/18 12:05 AM Re: 70-71- E-body dash wiring routing [Re: DAYCLONA]
DAYCLONA Offline
Loc: Mass
#2427049 - 01/01/18 10:57 AM Re: 70-71- E-body dash wiring routing [Re: DAYCLONA]
70Challengerse Offline
Loc: Lebanon ,PA in the Susquehanna...
Thanks again , that should do it, getting ready to wire it in a couple days.
One more question , where does the relay bolt to? (found it...) opps
Edited by 70Challengerse (01/01/18 11:28 AM)
70 Dodge Challenger se 440
71 Dodge Demon 416
71 V-Code Cuda
2016 Scatpak
Sometime words can serve me well,sometimes words can go to HELL... Harry Chapin
#2427356 - 01/01/18 04:54 PM Re: 70-71- E-body dash wiring routing [Re: 70Challengerse]
Alright wrapping this up ,I know I need to install diode yet, no problem there, I have a 2 wire plug connector for the headlight / key in buzzer, is this correct and do you have pics..
71 Dodge Demon 416
71 V-Code Cuda
2016 Scatpak
#2428107 - 01/02/18 10:38 PM Re: 70-71- E-body dash wiring routing [Re: 70Challengerse]
screamindriver Offline
Loc: Harrisburg, Pa.
Here's the key-in buzzer and the 70 road lamp relay...
#2428111 - 01/02/18 10:51 PM Re: 70-71- E-body dash wiring routing [Re: 70Challengerse]
71 road lamp relay and wiring diagram...
#2428634 - 01/03/18 09:47 PM Re: 70-71- E-body dash wiring routing [Re: 70Challengerse]
I'm posting this for 70challengerse...Here's a pic of his 71 harness...At this point he's got the wiring routed correctly and has 3 connectors in question...I've tagged them for easy reference..
Connector 1 ???
Connector 2 is flagged on his harness as the diode connector...
Connector 3 should be the 71 stand alone headlight buzzer
He needs confirmation and any additional info for these..Thanks
Page 2 of 2 < 1 2
25,538 Registered Members
194,156 Topics
Window Mechanism Grease
by dart4forte
10/23/18 12:55 AM
W2 heads- How much lift is lost at the valve?
by viperblue72
10/23/18 12:53 AM
HOW MUCH are you going to throw at the LOTTO ....
by Doc Fiberglass
10/22/18 11:54 PM
1971 Challenger A78 question.
by challenger6pack
10/22/18 11:47 PM
