Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2426923
01/01/18 03:03 AM
01/01/18 03:03 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By 70Challengerse
I would just like a pic of the switch in the vehicle, for the road lamp, thanks
I'll just post pics of 70/71 RALLEY dash switches only
Mike
roadlamp70cudaralley.JPGroadlamp70cudaralleydash.JPGroadlampralleydash70.JPGroadlampralleydash70cuda.JPG
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2426924
01/01/18 03:05 AM
01/01/18 03:05 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 70-71- E-body dash wiring routing [Re: DAYCLONA] #2427049
01/01/18 01:57 PM
01/01/18 01:57 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Thanks again , that should do it, getting ready to wire it in a couple days.
One more question , where does the relay bolt to? (found it...) opps
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2427356
01/01/18 07:54 PM
01/01/18 07:54 PM
Alright wrapping this up ,I know I need to install diode yet, no problem there, I have a 2 wire plug connector for the headlight / key in buzzer, is this correct and do you have pics..
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2428107
01/03/18 01:38 AM
01/03/18 01:38 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's the key-in buzzer and the 70 road lamp relay...
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2428111
01/03/18 01:51 AM
01/03/18 01:51 AM
Harrisburg, Pa.
Harrisburg, Pa.
71 road lamp relay and wiring diagram...
Re: 70-71- E-body dash wiring routing [Re: 70Challengerse] #2428634
01/04/18 12:47 AM
01/04/18 12:47 AM
Harrisburg, Pa.
Harrisburg, Pa.
I'm posting this for 70challengerse...Here's a pic of his 71 harness...At this point he's got the wiring routed correctly and has 3 connectors in question...I've tagged them for easy reference..
Connector 1 ???
Connector 2 is flagged on his harness as the diode connector...
Connector 3 should be the 71 stand alone headlight buzzer
He needs confirmation and any additional info for these..Thanks
