Coolest Dash? #2425085
12/28/17 10:15 PM
12/28/17 10:15 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Other than the 36 mono gage dash what are the cool dashes that mopar put out during the 30-50s?
Re: Coolest Dash? [Re: moparpollack] #2425424
12/29/17 05:09 PM
12/29/17 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'58 Imperial
Re: Coolest Dash? [Re: moparpollack] #2425439
12/29/17 05:53 PM
12/29/17 05:53 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Personally my all time favorite is the Chrysler Astrodome dash but as those didn't appear until 1960 that doesn't apply here.
For the 50's I'd have to go with the 1957-58 Dodge dashes.
Dodge dash 2 by M Patterson, on Flickr
Besides having a full set of gauge pods (that were actually pretty easy to read), the ash tray was kind of neat....rather than pull out it spun around.
While the 3 speed stick cars and two speed Powerflight cars had a conventional ignition switch, the switch on the Torqueflight equipped cars only had acc/off/run positions. To start the car you turned the switch to run and pushed in on the neutral button in the shifter pod.
The neatest part was the ribbon type speedometer with the red line that read off the speed.
dodge dash 1 by M Patterson, on Flickr
I'd actually considered using that dash in place of the original un my 57 Plymouth (it would have been a bolt in).
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: Coolest Dash? [Re: moparpollack] #2425440
12/29/17 05:53 PM
12/29/17 05:53 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
`58 neutral/starter share the same button haha , it took me a bit before I could hit neutral with out grinding starter.
Great looking dash with huge gauges. Chrome, chrome and then more chrome.
Re: Coolest Dash? [Re: moparpollack] #2425449
12/29/17 06:20 PM
12/29/17 06:20 PM
AZ
Mike P Offline
Mike P  Offline
AZ
".....`58 neutral/starter share the same button haha , it took me a bit before I could hit neutral with out grinding starter....."
The wiring from the N button switch to the starter solenoid is supposed to go thru a vacuum switch on the intake manifold that opens the circuit when the engine is running. Over the years I've seen far more bad switches (always closed) or wired around or the ignition switch replaced with a more conventional acc/off/run/start switch than I have seen cars that actually work the way they are supposed to.
Re: Coolest Dash? [Re: Mike P] #2426029
12/30/17 08:43 PM
12/30/17 08:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree My current '57 Dodge is stick shift so I have a traditional ign. sw. My previous '57 with auto went through 3 vacuum switches while I owned it. rant
