Page 1 of 4 1 2 3 4
Looking to 2018. What are you Building? #2424569
12/27/17 07:48 PM
12/27/17 07:48 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
I just picked up my first Gen3 Hemi core. It will be way behind the current curve but there are some good used parts for them floating around already priced right.
What are your plans?
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424575
12/27/17 07:54 PM
12/27/17 07:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've got a another 416 that I will build in the
spring when I get back.. I have everything for it
but I need to mill the pistons now
EDIT
I've been looking for a Gen 3 to put in my 38 ply
wave
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424580
12/27/17 08:00 PM
12/27/17 08:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Got a 418 i am gonna slap together with a roller,between 12.5 and 13 compression, and a set of the new trick flow small block heads
Will have a 904 behind it, and at 3300 pounds hoping it will run 10.20’s or so, wont need a license..... getting to old to want one or jump through those hoops anyhow.
In the meantime, want to get my stock stroke low compression 360 in the 10’s first......
And in between all that, get my hip replaced, its starting to really bug my mobility doing much of anything
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424589
12/27/17 08:13 PM
12/27/17 08:13 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm going to finish my 31 Plymouth and have it all tested and dialed in for Drag Week. The hemi is going on the Dyno mid January. Also I'm going to fix the issues with my 67 GTX that forced my to drop out of Drag Week 2017, so I have a good back up car, just in case.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424595
12/27/17 08:28 PM
12/27/17 08:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Trying to get back into it. I am looking at trying a new carb on the GTX and probably offing the 1000 race demon.
Been considering farming out all or part of the bodywork/paint on that car and think I may have met someone who could turn out to be a good resource. Need to invest some time with this person and get an idea what will need to happen. (I already know I'm not going to like the price).
I will be shopping around to find somewhere good to rework/prep and port the small pile of heads I collected a few years back. Hasn't been much interest from the famous names here so I might have to actually talk to people in real life, which I actually welcome...just need to find the time....there is a crazy amount of knowledge locally that I haven't really attempted to tap into and that's probably a mistake.
Need to take the time to scrutinize the LA small block-related items in the collection closely and need to work towards selling off the stuff I'm not going to use anytime soon.
Rich H.
Esse Quam Videri
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424596
12/27/17 08:33 PM
12/27/17 08:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have a set of G3 ported Eddy heads, and I just scored a mint 400 block, and a set of new Hedman fenderwll headers, and I am just finishing the install of my 605 Hemi in the Cuda....
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424602
12/27/17 08:49 PM
12/27/17 08:49 PM
tboomer Online work
tboomer  Online Work
A new house... whistling
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424609
12/27/17 09:05 PM
12/27/17 09:05 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
69 GTX clone street/strip car - shooting for low to mid 10's
Re: Looking to 2018. What are you Building? [Re: markz528] #2424617
12/27/17 09:18 PM
12/27/17 09:18 PM
oregon
greendart408 Offline
oregon
Work at making more than 5 passes next yr, tune my new f2 w8 combo so it will actually run right, and get my other 69, 340, 4spd dart drivable from a 1976 hibernation and drive to hot August nights.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424619
12/27/17 09:30 PM
12/27/17 09:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Making a billet intake to go on my billet HEMI.
Finally got my CNC up and running in my shop. Hope to be making chips next month. Then plan on making an oil pan and several other parts.
Also have plans for an expansion at my storage business. Should be a busy year.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424623
12/27/17 09:33 PM
12/27/17 09:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Retirement, lol.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424636
12/27/17 10:04 PM
12/27/17 10:04 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Built myself a 11.3:1 cr 360 engine recently to be put in my '73 daily Dart.
Maybe somewhere down the line I hope to also be able to finally build/finish an Early 392, a 5.7L Hemi and a 6.1L Hemi.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424641
12/27/17 10:17 PM
12/27/17 10:17 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Heads and Manifold are off for a visit to Shane Studley...Precision Cylinder Heads in Utah, converter is off to Lenny for a re-flash, engine and tranny freshen up.
Moving the engine back 4".
So not much.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424646
12/27/17 10:33 PM
12/27/17 10:33 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I'm hoping to get my car in the 5.0 range .
Need to start working on my 73 dodge / oleynik car hauler and get that sold .Maybe get my 67 coronet running and drive that this summer .
Re: Looking to 2018. What are you Building? [Re: Adobedude] #2424648
12/27/17 10:40 PM
12/27/17 10:40 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
I've got half the paint striped off the dart. Making way for a new paint job
Putting a glass rear bumper to match the front.
Adding an engine plate and denso alternator
Possibly a fiberglass dash if I'm really feeling froggy.
Looking forward to working in my new garage. This will be my first big project.
Any folks around Kentucky are more than welcome to stop by and lend a hand....
Jeff
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424655
12/27/17 10:46 PM
12/27/17 10:46 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
New mill for my old girl. The 500 seemed to be possessed by the spirit of Chuckie. Overhaul my Indy Max block. Figure out if going 572 or 605. Not sure which stroke to use yet.
[image][/image]
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424671
12/27/17 11:09 PM
12/27/17 11:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Down sizing!
Fastest 300
Re: Looking to 2018. What are you Building? [Re: Porter67] #2424678
12/27/17 11:25 PM
12/27/17 11:25 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Redoing my blowed up 383 sbm... finish my dirt late model project... maybe start on the G3 5.7 I have...
Re: Looking to 2018. What are you Building? [Re: rickraw] #2424682
12/27/17 11:32 PM
12/27/17 11:32 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By rickraw
Retirement, lol.
Congrats!!
Fastest 300
Re: Looking to 2018. What are you Building? [Re: Hemi_Joel] #2424685
12/27/17 11:36 PM
12/27/17 11:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Finished my 33 about 1.5 years ago. Fun driver.
Fastest 300
Page 1 of 4 1 2 3 4
