Re: Looking to 2018. What are you Building?
[Re: Porter67]
#2424575
12/27/17 07:54 PM
12/27/17 07:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've got a another 416 that I will build in the spring when I get back.. I have everything for it but I need to mill the pistons now EDIT I've been looking for a Gen 3 to put in my 38 ply
[Re: Porter67]
#2424580
12/27/17 08:00 PM
12/27/17 08:00 PM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
Got a 418 i am gonna slap together with a roller,between 12.5 and 13 compression, and a set of the new trick flow small block heads Will have a 904 behind it, and at 3300 pounds hoping it will run 10.20’s or so, wont need a license..... getting to old to want one or jump through those hoops anyhow. In the meantime, want to get my stock stroke low compression 360 in the 10’s first...... And in between all that, get my hip replaced, its starting to really bug my mobility doing much of anything
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Porter67]
#2424589
12/27/17 08:13 PM
12/27/17 08:13 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
I'm going to finish my 31 Plymouth and have it all tested and dialed in for Drag Week. The hemi is going on the Dyno mid January. Also I'm going to fix the issues with my 67 GTX that forced my to drop out of Drag Week 2017, so I have a good back up car, just in case.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Porter67]
#2424595
12/27/17 08:28 PM
12/27/17 08:28 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Trying to get back into it. I am looking at trying a new carb on the GTX and probably offing the 1000 race demon.
Been considering farming out all or part of the bodywork/paint on that car and think I may have met someone who could turn out to be a good resource. Need to invest some time with this person and get an idea what will need to happen. (I already know I'm not going to like the price).
I will be shopping around to find somewhere good to rework/prep and port the small pile of heads I collected a few years back. Hasn't been much interest from the famous names here so I might have to actually talk to people in real life, which I actually welcome...just need to find the time....there is a crazy amount of knowledge locally that I haven't really attempted to tap into and that's probably a mistake.
Need to take the time to scrutinize the LA small block-related items in the collection closely and need to work towards selling off the stuff I'm not going to use anytime soon.
Rich H.
Esse Quam Videri
[Re: Porter67]
#2424596
12/27/17 08:33 PM
12/27/17 08:33 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
I have a set of G3 ported Eddy heads, and I just scored a mint 400 block, and a set of new Hedman fenderwll headers, and I am just finishing the install of my 605 Hemi in the Cuda....
[Re: Porter67]
#2424609
12/27/17 09:05 PM
12/27/17 09:05 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
69 GTX clone street/strip car - shooting for low to mid 10's
[Re: Porter67]
#2424641
12/27/17 10:17 PM
12/27/17 10:17 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Heads and Manifold are off for a visit to Shane Studley...Precision Cylinder Heads in Utah, converter is off to Lenny for a re-flash, engine and tranny freshen up. Moving the engine back 4".
So not much.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2424648
12/27/17 10:40 PM
12/27/17 10:40 PM
Posts: 252 southeast ky
mills.mopar
southeast ky
I've got half the paint striped off the dart. Making way for a new paint job Putting a glass rear bumper to match the front. Adding an engine plate and denso alternator Possibly a fiberglass dash if I'm really feeling froggy. Looking forward to working in my new garage. This will be my first big project. Any folks around Kentucky are more than welcome to stop by and lend a hand.... Jeff
If you love it lube it
68 dart 37 dodge coupe 71 challenger
[Re: Porter67]
#2424655
12/27/17 10:46 PM
12/27/17 10:46 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
New mill for my old girl. The 500 seemed to be possessed by the spirit of Chuckie. Overhaul my Indy Max block. Figure out if going 572 or 605. Not sure which stroke to use yet.
[image][/image]
[Re: Hemi_Joel]
#2424685
12/27/17 11:36 PM
12/27/17 11:36 PM
Posts: 7,506 Az
Crizila
Az
I'm going to finish my 31 Plymouth and have it all tested and dialed in for Drag Week. The hemi is going on the Dyno mid January. Also I'm going to fix the issues with my 67 GTX that forced my to drop out of Drag Week 2017, so I have a good back up car, just in case. Finished my 33 about 1.5 years ago. Fun driver.
Fastest 300
