Re: Rear Leaf Springs - OE or Competition - Super Stock?
[Re: vinnyd76]
#2424110
12/26/17 09:55 PM
12/26/17 09:55 PM
RapidRobert
I had 002/003 SS on a 65 SB dart (came that way as a roller) & it rode high and tight when done (daily driver). I was happy with em.
[Re: vinnyd76]
#2424125
12/26/17 10:13 PM
12/26/17 10:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I run oval track springs https://www.summitracing.com/parts/DCC-4529414/Mopar offers more than the two choices you mention and if you don't mine aftermarket AFCO makes a bunch more choices. I run them because the spring rate works for me and I do not like poor handling of the jacked up butt look.
[Re: buildanother]
#2424317
12/27/17 12:10 PM
12/27/17 12:10 PM
Posts: 4,687 Wichita
GY3
Wichita
I used the 456/457 MP SS springs. They lost their arch and quit working after about a year. They did work well to begin with but started wrapping up horribly.
I went with Cal-Trac split mono's and happy so far! The car wanted completely different torsion bar setting and leaves smooth and level now.
[Re: RapidRobert]
#2424873
12/28/17 02:08 PM
12/28/17 02:08 PM
Posts: 4 Georgia
Korican
Georgia
I had 002/003 SS on a 65 SB dart (came that way as a roller) & it rode high and tight when done (daily driver). I was happy with em. Which shocks did you go with?
[Re: Korican]
#2425161
12/28/17 11:55 PM
12/28/17 11:55 PM
RapidRobert
I had 002/003 SS on a 65 SB dart (came that way as a roller) & it rode high and tight when done (daily driver). I was happy with em. Which shocks did you go with? since it was a DD I used some cheap parts house A body length ones that I already had on hand & they needed shock extensions which I also happened to have some in my stash. sometimes things go the right way. I shoulda kept it.
