Intake manifold options for Eagle 5.7 #2424233
12/27/17 01:54 AM
12/27/17 01:54 AM
Northern Colorado
E
EagleDuster Offline OP
E
Northern Colorado
I've been trying to get a definitive list of intake manifolds going to figure out what's best to put on my engine. I have a 5.7 which was pulled from a 2014 Ram truck and I want to swap it into my '70 Duster (eventually, gotta save up the money first lol). My plan is to use the MP PCM and harness kit and reuse the factory EFI and ignition. The stock truck intake that came with it has a broken dual-runner actuator on the back. Would this be worth fixing and a good choice for an A-body swap or would something else be better? I know there's also the later 5.7 car intake, the "old" aluminum 6.1 intake, the 6.4 SRT manifold with dual-length runners, and the aftermarket aluminum single-planes. I think the 6.4 manifold is cool but those seem to be pretty rare used, it's not like I'm going to have this thing running anytime soon though so maybe I should just wait and keep an eye out?
EDIT: Also planning on using a replacement 6.4 SRT cam and deleting the MDS along with new springs, pushrods and lifters. Transmission will be some kind of overdrive 5- or 6-speed manual (thinking T-56 atm).
Khalid
1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424268
12/27/17 03:59 AM
12/27/17 03:59 AM
houston texas
gremlinsteve Offline
houston texas
You also have the edelbrock intake. The upcoming intake from Holley will be out soon I hear and another project is in the works for a sheet metal design using a shorter extruded runner
And billet flanges
I'll have the design completed soon I hope and will start work on the prototype
That's all I can give as far as details at this moment
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424278
12/27/17 07:50 AM
12/27/17 07:50 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Don't waste your time on fixing the truck manifold,its not a bad intake, but the car/Jeep intakes pop up regularly on eBay in the 150-400 range, and places the TB in a horizontal position, makes for better air cleaner options.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424282
12/27/17 07:55 AM
12/27/17 07:55 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
As for a list of intakes
Ritter- single plane
Drag Pak - single plane
Mod man.....not sure what you would call that
OCP- dual plane
Edelbrock- barrel stock type
Edelbrock- dual 4 bbl intake
XV single plane....ultra rare, made back in 08-?
And of course the stockers.
The is also a BDS intake for the 671/871
Mopar has a f--ing expensive single 4bbl intake
And a few sheet metal options from different fabricators.
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424284
12/27/17 09:01 AM
12/27/17 09:01 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Forgot the Arrow Single plane intake.
The Holley Sniper intake is easy to modify if your good with welding,
I've seen a Northstar Eaton M122 intake/blower (04-08?) modified to work on the g3 motor, issue with that is 1) it's a Eaton , 2) the TB is in the back right up against the fire wall on the ram truck it was it, I would think in a retro fit(A/B Body) the TB would be in the firewall.
Porsche Caymen Intake modified to work on a G3.....not worth the effort runners are the same length as a 6.1 Barrel intake.
I've been working on a Cross-ram based off of the G2 viper...yeah trust me when I say it's not that great, money could of been better spent.
Re: Intake manifold options for Eagle 5.7 [Re: ric3xrt] #2424416
12/27/17 03:29 PM
12/27/17 03:29 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
QUOTE: The Holley Sniper intake is easy to modify if your good with welding,
Sure like to know more about this! Pics?? Details?? Intake flange angle obviously, but were there port spacing issues?
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424423
12/27/17 03:40 PM
12/27/17 03:40 PM
houston texas
houston texas
No need to modify a sniper
They are releasing one
I have the spy phot to prove it
Re: Intake manifold options for Eagle 5.7 [Re: cudadoug] #2424490
12/27/17 05:04 PM
12/27/17 05:04 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Like Steve said Holly is going to release one soon.
but spacing is 99% identical to the G3, the LS7 & LSX are closer to the pre Eagle shape then the 6.1/6.4 Eagle head.
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424504
12/27/17 05:26 PM
12/27/17 05:26 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Back in late 2013 thru early 2014 the company I work for did Endurance testing on intakes based off of or similar to Holley 300-130,300-131,300-124 & 830031. 5 engines each intake, we were looking for real world flow issues.
With the Challenger selling like it has and FC pushing Retro fit G3s it's only a matter of time before the After market catches up to the demand.
We were told at the time the big issue was the approach angle to the intake port, because it's horizontal and not angled getting the flow to maintain speed and still be able to keep the intake under the hood , hence why the Drag Pak is Sooooooooo F--ing tall.
Due to an N.D.A That's all I'll say.
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424558
12/27/17 07:27 PM
12/27/17 07:27 PM
Northern Colorado
E
E
Northern Colorado
Wow lots of info thanks guys! I guess now for me it's a toss-up between a Jeep/car intake and one of the 4-bbl-style aftermarket single planes. Since I'll need another TB anyway is there a vertical one out there which will fit the aftermarket intakes and still work with the factory drive-by-wire and EFI? I'd love to be able to still make use of the functional dual-snorkel hood scoop and 14x3" K&N filter on my Duster...
Khalid
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424712
12/28/17 12:31 AM
12/28/17 12:31 AM
houston texas
houston texas
I think the ocp intake does
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2424793
12/28/17 09:38 AM
12/28/17 09:38 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
My niece had one on her challenger, for what the car was at the time it was one of the better intakes we had on it.
I know of 2 Ram guys and one B-body guy who love this intake.
The owner Joe pops in here once in a while. hemijoejr
http://ocperformanceparts.com/home
https://www.youtube.com/watch?v=8oqSSfW4MRo
Re: Intake manifold options for Eagle 5.7 [Re: ric3xrt] #2425049
12/28/17 08:36 PM
12/28/17 08:36 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How close did the Cadillac Eaton M122 match up to the Hemi? Bore spacing smaller? Adapters used?
Re: Intake manifold options for Eagle 5.7 [Re: ric3xrt] #2425055
12/28/17 09:00 PM
12/28/17 09:00 PM
Northern Colorado
E
E
Northern Colorado
That's a really nice-looking piece, if I was going carb'd I'd use that in a heartbeat. However for EFI I want to stick with one of the single planes (prob Arrow Racing) or one of the stock plastic ones. That TB adapter kit OCP makes is sweet, if I do end up using a single-plane I'm definitely getting one of those kits for it.
Khalid
Re: Intake manifold options for Eagle 5.7 [Re: EagleDuster] #2425694
12/30/17 11:03 AM
12/30/17 11:03 AM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
OP performance intake has a DBW adapter plate for the 4150 pattern for his intake. Im thinking on doing that myself on my 5.7 Eagle build
Re: Intake manifold options for Eagle 5.7 [Re: WO23Coronet] #2425744
12/30/17 12:53 PM
12/30/17 12:53 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
How close did the Cadillac Eaton M122 match up to the Hemi? Bore spacing smaller? Adapters used? [/quote]
Northstar is only a 4 inch bore center, the intake spacing is 4.25, adaptor was a 1 inch think by 2.5 wide piece of alum, during the conversation about the trail and error fitting , he started with lining up the intake as best he could on the center 4 cylinders, and did all the port transition work in the adaptor.
