Page 1 of 2 1 2 >
#2423831 - 12/26/17 12:23 AM 67-up Dart. Roll bar with back seat?
cudadoug Offline
Loc: Between a rock & a hard place
Let's see pics! Does any kit come with bars through the package tray or is that a custom bent deal?
If one has tilting forward seat backs (OEM) to access the back seat, how do you get around that the seats aren't securely mounted to the cross bar?
Thank you!
#2423836 - 12/26/17 02:23 AM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
StealthWedge67 Offline
Loc: Puyallup, WA
Most companies offer “seat saver” bars with a bend that are designed to pass through the package tray as an added option to their kit. I just bought an Art Morrison bar, but paid the extra to have those bars custom bent to my dimensions so they will follow the roofline and rear glass tightly.
Edited by StealthWedge67 (12/26/17 02:55 AM)
LemonWedge - Street heavy / Strip ready - 11.32 @ 117
#2423854 - 12/26/17 08:32 AM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
mopar dave Offline
Loc: flint michigan
I believe mine are S&W and they go thru speaker opening in back deck retaining the back seat.
#2423866 - 12/26/17 09:19 AM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
dvw Offline
Loc: MI, usa
Stock seats are not required to be attached to the shoulder bar. Rear passengers still have the luxury of climbing over the shoulder bar for access.
Doug
#2423879 - 12/26/17 10:17 AM Re: 67-up Dart. Roll bar with back seat? [Re: mopar dave]
justinp61 Offline
Loc: W. Kentucky
Same here. I don't let anyone ride in the back seat though, if something ever went wrong the rear bars are a good way to get a head cracked.
#2423898 - 12/26/17 11:13 AM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
jbc426 Offline
Loc: West Coast, USA
Here's a picture of the bar in my '68 A-body.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 3.73s
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
#2423950 - 12/26/17 01:51 PM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
cudadoug Offline
Thanks guys, I failed to google it before I posted this...I see seat saver bars in a few kits out there.
Thanks, Doug about the stock seat issue. That makes the whole OE seat deal make sense.
#2423951 - 12/26/17 01:51 PM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
cudadoug Offline
Whoops...double post.
Edited by cudadoug (12/26/17 01:52 PM)
#2423959 - 12/26/17 02:15 PM Re: 67-up Dart. Roll bar with back seat? [Re: justinp61]
B3422W5 Offline
Loc: Portage,michigan
Cage getting installed in my 69 dart as we speak is SW with the back bars through package tray. 8 point with swingouts on both sides.
My guy doing it likes the SW stuff
69 Dart GTS, performance upgrades in progress
11.26@ 118.40 best so far. Stock 360 shortblock with eddie heads.
3285 race weight
#2424054 - 12/26/17 04:53 PM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
humpty Offline
Loc: Minnesota, USA
Here's a couple shots of the rear seat saver bars from an S&W kit. They were an add on to their 8 point roll bar kit. I couldn't find a picture with the seat installed but you get the point. The last shot shows the swing out bars if your looking at them too.
72 Duster - 408ci W2, 10.18@131, 6.31@110.
https://m.youtube.com/watch?v=Q4P51j38-MI
#2424083 - 12/26/17 05:42 PM Re: 67-up Dart. Roll bar with back seat? [Re: humpty]
GY3 Offline
Loc: Wichita
Find a good chassis shop near you and have it custom bent!
They knew little tricks and suggested things I hadn't thought of.
Holzman Race Cars did mine.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's
10.69 @ 128mph with 150hp shot of nitrous
#2424336 - 12/27/17 09:40 AM Re: 67-up Dart. Roll bar with back seat? [Re: dvw]
moparx Offline
Dreaming of implants
Loc: north of coder
Doug
doug, what happens if you use stock "production" seats in a hot rod that never had those particular seats ? example : i'm using factory buckets from a '95 caravan in my 33 dodge "humpback" panel truck with a cage. i have been thinking how i can attach the back to the cross bar, and there is no back seat to "save". thanks.
beer
#2424351 - 12/27/17 10:19 AM Re: 67-up Dart. Roll bar with back seat? [Re: humpty]
360tripleblack77 Offline
Loc: Gravataí, RS, Brazil
Nice work man! I'm planning install mine next month and probably I will make something like yours.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
#2424367 - 12/27/17 10:59 AM Re: 67-up Dart. Roll bar with back seat? [Re: 360tripleblack77]
Gary Robbins Offline
Loc: Idabel,Oklahoma
Here's my 70...Pics not so good !!
#2424385 - 12/27/17 11:28 AM Re: 67-up Dart. Roll bar with back seat? [Re: Gary Robbins]
A little better pics !!
#2424488 - 12/27/17 01:48 PM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
68 HEMI GTS Offline
Loc: Temperance, MI
If I knew how to post pics I would post some of mine. Cannot Get Flickr to work. Anyone else know if an app?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
#2424574 - 12/27/17 04:53 PM Re: 67-up Dart. Roll bar with back seat? [Re: cudadoug]
cudaman1969 Offline
Loc: fredericksburg,va
One thing to remember, if doing the outrigger bars (comes off the hoop under the seat bar over to the frame conectors) the nose of the lower seat protrudes out to far and will hit. Depends on how far back you install the main hoop. That bar is required if racing, just street, don't use them. I had to cut the braces inside the seat so they could fold up and go between the hoop bars. Thought about reworking the seat frame to fit then reinstall the cover. Seat back installs first with a lot of twisting-bending (both do). Finally didn't use the seats because I added a bar down to the top of spring mount (high pressure point on leaf spring suspension). Might use the seat back then put the lower cover on a made up box type affair.
#2424634 - 12/27/17 06:54 PM Re: 67-up Dart. Roll bar with back seat? [Re: moparx]
dvw Offline
Loc: MI, usa
Pull the seat cover off then attach your mount to the frame. On my 64 I used the head rest tube locations to fab a mount that came through the rear seat cover.
Doug
#2424702 - 12/27/17 09:14 PM Re: 67-up Dart. Roll bar with back seat? [Re: GY3]
ProSport Offline
Loc: Akron, Ohio
I agree, you'll be much happier. I had ChassisFab Performance do mine in Tallmadge Ohio. Mine is just a 6-point street car bar and I wanted it to fit the seat and arm rest and to be easy to get in and out of the car. The rear bars had to go behind my 6x9 speakers.
Sassy Grass street Duster, best of 10.69 at 124 driven to the track with 3.23 gears, naturally aspirated on 93 octane.
#2424833 - 12/28/17 09:39 AM Re: 67-up Dart. Roll bar with back seat? [Re: dvw]
moparx Offline
Loc: north of coder
Doug
thank you ! as the second row buckets i'm using have detachable head rests [with the attaching tubes like your seat[s] have], i will use those as you did for the mount attachment point. i have to cut into the lower seat pan to get the seat to fit the chassis kickup, then i can properly locate the cross bar so the shoulder belts are in the correct height. i also plan to make a shoulder belt guide that will locate off of the head rest posts to keep the belts properly aligned. thanks again for suggesting the use of the head rest mounting tubes for the location of the back brace attaching point ! bow
beer
Page 1 of 2 1 2 >
25,635 Registered Members
195,683 Topics
15 Grand Caravan
by zrxkawboy
51 minutes 39 seconds ago
Lookin at a 392 GEN 3
by HDNMOPERS
Today at 03:27 PM
m-76 Micro precision bubble balancer
by polaris400cc
Today at 03:15 PM
572 going to the Dyno
by JACK1440
Today at 03:14 PM
