RAM TECHS HELP 08 CRUISE INTERMITTENT
#2423053
12/24/17 12:49 PM
12/24/17 12:49 PM
crabman173
crabman173
My 08 Ram 1500 has been experiencing trouble with cruise control--it will work fine then switch will not turn it on --then later it does --after few miles it turns off OK I had truck in dealer for inspection ask them to trouble shoot--They came back it is the switch so I buy one install it myself and guess what? It is not the switch What to do here gang --any ideas??? Thanks for the help
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT
[Re: ]
#2423274
12/24/17 08:43 PM
12/24/17 08:43 PM
Posts: 2,046 ky.
kenworth_goose
ky.
[Re: ]
#2423386
12/25/17 01:20 AM
12/25/17 01:20 AM
crabman173
crabman173
Ugh what?? Thanks for helping
[Re: ]
#2423858
12/26/17 11:47 AM
12/26/17 11:47 AM
crabman173
crabman173
Ok so I have read up on all the issues with TIPm so what do I do? hard reset? Replace the entire TIPM for cruise issue? that sounds scarey more info please Thanks
[Re: ]
#2424180
12/27/17 12:00 AM
12/27/17 12:00 AM
Posts: 859 Southeast Pa.
SALEM1912
Southeast Pa.
Possible clock spring? Does the lite in dash stay on?
[Re: ]
#2424297
12/27/17 10:56 AM
12/27/17 10:56 AM
crabman173
crabman173
No other issues--at times cruise light works will come on--set cruise--all good then green cruise light goes out --no cruise wait push on off button--nothing--then in a minute it starts working again all other items work fine dealer said switch so I replaced it --no diff wiggled and pushed all fuses--nothing Horn and all other items on steering work so guessing clock spring ok? It is just the cruise--works sometimes them not --will not stay on and work more than a few minutes Thanks for ideas--it is driving me crazy No codes shown at the moment
[Re: ]
#2424995
12/28/17 06:23 PM
12/28/17 06:23 PM
crabman173
crabman173
[Re: stumpy]
#2425750
12/30/17 01:02 PM
12/30/17 01:02 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
When this happened in our mini van, I was told it was the clock spring and that it also affected anti lock brakes. I have driven most of my life with out either of those functions, so I just blocked the lite on the dash. Several years later & still no issues.
I have mechanical Aptitude. I can screw up anything.
[Re: SALEM1912]
#2427360
01/01/18 08:01 PM
01/01/18 08:01 PM
crabman173
crabman173
Possible clock spring? Does the lite in dash stay on? dash light might come on for a while--then goes out--it is hit or miss if it will stay on or not but only stays on a while then pops out/off Tried brake light switch --Nope--replaced switch in steering wheel --Not that either Horn and all other stuff on steering wheel works so could it still be clock spring? What about the TIPM? Do I just need a hard reset--like attach the battery cables together for an hour or so to reset--does that work will it help/ can it hurt anything? Wiggled all the fuses etc no change
