RAM TECHS HELP 08 CRUISE INTERMITTENT #2423053
12/24/17 12:49 PM
12/24/17 12:49 PM
crabman173 OP
crabman173 OP
My 08 Ram 1500 has been experiencing trouble with cruise control--it will work fine then switch will not turn it on --then later it does --after few miles it turns off
OK I had truck in dealer for inspection ask them to trouble shoot--They came back it is the switch so I buy one install it myself and guess what? It is not the switch
What to do here gang --any ideas??? Thanks for the help
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2423274
12/24/17 08:43 PM
12/24/17 08:43 PM
ky.
K
kenworth_goose Offline
K
ky.
TIPM
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2423386
12/25/17 01:20 AM
12/25/17 01:20 AM
crabman173 OP
crabman173 OP
Ugh what??
Thanks for helping
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2423805
12/26/17 01:12 AM
12/26/17 01:12 AM
ky.
K
K
ky.
total integrated power module, or otherwise known as the fuse box under the hood by the battery.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2423858
12/26/17 11:47 AM
12/26/17 11:47 AM
crabman173 OP
crabman173 OP
Ok so I have read up on all the issues with TIPm so what do I do? hard reset? Replace the entire TIPM for cruise issue? that sounds scarey more info please Thanks
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424180
12/27/17 12:00 AM
12/27/17 12:00 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Possible clock spring? Does the lite in dash stay on?
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424191
12/27/17 12:22 AM
12/27/17 12:22 AM
ky.
K
K
ky.
I'd buy the tipm from a dealer near you, you can install it yourself. After it's hooked back up you turn the key on for 12 seconds, turn it back off, start the truck as normal. Remember you have to push the fuse in for the airbag module. What I do is go through and push all of the fuses and relays in to make sure and all should be good. Are you having any other issues?
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424192
12/27/17 12:25 AM
12/27/17 12:25 AM
ky.
K
K
ky.
My truck kicked the cruise off when the "service 4wd" light would come on.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424249
12/27/17 02:38 AM
12/27/17 02:38 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Does the speedo quit when the cruise does? The reason is a speed sensor will cause the cruise to quit also.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424297
12/27/17 10:56 AM
12/27/17 10:56 AM
crabman173 OP
crabman173 OP
No other issues--at times cruise light works will come on--set cruise--all good then green cruise light goes out --no cruise
wait push on off button--nothing--then in a minute it starts working again
all other items work fine
dealer said switch so I replaced it --no diff
wiggled and pushed all fuses--nothing
Horn and all other items on steering work so guessing clock spring ok?
It is just the cruise--works sometimes them not --will not stay on and work more than a few minutes
Thanks for ideas--it is driving me crazy
No codes shown at the moment
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424612
12/27/17 09:08 PM
12/27/17 09:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Does it work better if you hold the pedal up? Maybe the switch located there?
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2424995
12/28/17 06:23 PM
12/28/17 06:23 PM
crabman173 OP
crabman173 OP
will try that thanks
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2425002
12/28/17 06:59 PM
12/28/17 06:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the brake light switch.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: stumpy] #2425750
12/30/17 01:02 PM
12/30/17 01:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
When this happened in our mini van, I was told it was the clock spring and that it also affected anti lock brakes.
I have driven most of my life with out either of those functions, so I just blocked the lite on the dash.
Several years later & still no issues.
I have mechanical Aptitude.
I can screw up anything.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: SALEM1912] #2427360
01/01/18 08:01 PM
01/01/18 08:01 PM
crabman173 OP
crabman173 OP
dash light might come on for a while--then goes out--it is hit or miss if it will stay on or not but only stays on a while then pops out/off
Tried brake light switch --Nope--replaced switch in steering wheel --Not that either
Horn and all other stuff on steering wheel works so could it still be clock spring?
What about the TIPM? Do I just need a hard reset--like attach the battery cables together for an hour or so to reset--does that work will it help/ can it hurt anything? Wiggled all the fuses etc no change
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2427388
01/01/18 08:54 PM
01/01/18 08:54 PM
ky.
K
K
ky.
TIPM replacement. Hood it up, push the airbag module fuse in the rest of the way so you don't get an airbag light, turn the ign key to the on position for 12 seconds, turn back to off, turn back on and start the vehicle.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2427517
01/02/18 12:53 AM
01/02/18 12:53 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes on the clockspring question. Everything but cruise could work and it still be bad. It has a number of different circuits in it.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: stumpy] #2427533
01/02/18 01:16 AM
01/02/18 01:16 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Car sitting still turn CC on (dash lite on) turn steering wheel back and forth lite turn or hard watch for dash lite to cancel if it does Clock spring is bad. Clock spring get the most wear in the 11/12/1 o'clock position. Also it tilt wheel move that up and down wiring to clock spring may have a split.
Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: ] #2427554
01/02/18 01:59 AM
01/02/18 01:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't think the cruise will come on unless the vehicle is moving above 25mph.
