4150 or 4500 carb?? #2423180
12/24/17 05:52 PM
12/24/17 05:52 PM
N.W. Indiana
DblOJoe Offline OP
DblOJoe  Offline OP
N.W. Indiana
Thinking about trying a 4500 but would like some opinions here's my combo.
446Ci 440 10.5 compression Trick Flow 240 heads 267@ .050 solid flat tappet. Victor Intake and a 80496-1 950 hp that's had some work done by Thumper. Runs on 93 pump gas. The rest of the car is 8" 5800 converter 4.10 Dana (Originally was 4.30 8 3/4 but it broke) Car weighs 3470 now with me and last time out in pretty good air it went 10.39 @ 127
The 950 runs great and has awesome shift recovery so that and the car weight has me skeptical. Thoughts???
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423193
12/24/17 06:19 PM
12/24/17 06:19 PM
AndyF Offline
AndyF  Offline
A Wilson ported M1 combination like I used with my 240 heads would add 30 or 40 hp to your combo but it is expensive.
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423200
12/24/17 06:29 PM
12/24/17 06:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you have room for a 2" adapter...........
Re: 4150 or 4500 carb?? [Re: Thumperdart] #2423220
12/24/17 07:10 PM
12/24/17 07:10 PM
N.W. Indiana
DblOJoe Offline OP
DblOJoe  Offline OP
N.W. Indiana
Yes, plenty of room.
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423290
12/24/17 09:32 PM
12/24/17 09:32 PM
Every stock stroke 440 motor I added increase CFM with the carb. and intake size ran quicker and faster up Six pack outran a single four barrel and the tunnel rams with two bigger carbs. outran the six packs, same thing on going from a single 600 Holley double pumper in 1000 CFM increments up to a 950 HP, bigger was faster and quicker up boogie wrench
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423314
12/24/17 10:04 PM
12/24/17 10:04 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Sounds like a ton of convertor.5800 flash?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 4150 or 4500 carb?? [Re: B3422W5] #2423388
12/25/17 01:21 AM
12/25/17 01:21 AM
N.W. Indiana
DblOJoe Offline OP
DblOJoe  Offline OP
N.W. Indiana
Yep
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423415
12/25/17 02:47 AM
12/25/17 02:47 AM
ky
68roadrunner Offline
ky
i went from a gas 950 to alky 950 on my 446 and it liked it, then it really liked a 1050 alky carb
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423420
12/25/17 03:10 AM
12/25/17 03:10 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You could try a 1050 then but imo, fully blending/porting it into the plenum is best......... thumbs
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423899
12/26/17 02:14 PM
12/26/17 02:14 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
That seems to run good. Similar to my combo. I was told to run a 4500 but I'm gonna run the quickfuel 1050an i have when I get it back together.
Re: 4150 or 4500 carb?? [Re: DblOJoe] #2423970
12/26/17 05:30 PM
12/26/17 05:30 PM
crabman173
crabman173
Drag only they usually really like a dominator--get the 2 inch adapter --smooth around in there no big deal and I bet you will likey!!
Re: 4150 or 4500 carb?? [Re: AndyF] #2424024
12/26/17 06:47 PM
12/26/17 06:47 PM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
how much porting did they do ?
and if you do not mind what is the price for something like that ?
thanks
