Wheels for the slicks #2423090
12/24/17 02:18 PM
12/24/17 02:18 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Where can I get wheels , the size and off set that I need for the slicks..I know Summit and Jegs sell wheels but I gotta get the off needed.
Re: Wheels for the slicks [Re: dynamite] #2423109
12/24/17 02:58 PM
12/24/17 02:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
would be nice to have a little more information.
Re: Wheels for the slicks [Re: stumpy] #2423126
12/24/17 03:49 PM
12/24/17 03:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
up iagree
What year car, size of slicks and which width wheels do you want information on?
Re: Wheels for the slicks [Re: dynamite] #2423130
12/24/17 04:01 PM
12/24/17 04:01 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
maybe ask in the drag race forum
drag wheels might be different than ROAD RACE wheels
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Wheels for the slicks [Re: dynamite] #2423155
12/24/17 04:49 PM
12/24/17 04:49 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
wheels.com
Re: Wheels for the slicks [Re: Magnum] #2423181
12/24/17 05:56 PM
12/24/17 05:56 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
thanks for the replies guys.. didn't think TO give the specs .. I just needed a manufacture to contact ..I guess I could use 15 or 16 inch wheels , 5 0n 4.5 I will try wheels inc..
Re: Wheels for the slicks [Re: dynamite] #2423383
12/25/17 01:13 AM
12/25/17 01:13 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used wheels made by Bassett from Summit. I got the IMCA five spoke Inertia light wheels.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Wheels for the slicks [Re: dynamite] #2423985
12/26/17 05:47 PM
12/26/17 05:47 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Car, springs, rear housing, rear brake type, and tire size are all factors in what will or wont fit. Nearly any manufacturer may have off the shelf versions that fit, but if you have changed any of these items from stock, then you may have to modify the wheel requirements. I doubt even a very knowledgeable wheel manufacturer will know as much about any particular mopar combo and wheels that may or may not fit than the people in these forums.
Re: Wheels for the slicks [Re: dynamite] #2425300
12/29/17 12:31 PM
12/29/17 12:31 PM
Locomotion Offline
Locomotion  Offline
Finding someone with a similar car body and suspension mods to what you have will help. Otherwise, find any wheel/tire combo to establish a baseline and add/subtract width & offset to see what range will fit.
* Use the widest wheel that will fit the slick. Wider wheels allow more air pressure which helps maintain a flat footprint and firmer, longer lasting sidewalls. (i.e.: 10" wide rim with 9" slicks.)
* You have to take into account the width of the tire sidewall bulge for spring & inner/outer fender clearance. Wider wheels will increase that measurement over what is "standard" in tire specs.
* Watch tire diameter clearance.
* The widest variety of slicks are for 15" wheels.
